vinod Posted January 14, 2009 Posted January 14, 2009 I want to plot a simple 3D object. Here I am attaching the sample screenshot which I got . How can remove unwanted lines ? Is there any system settings ? Quote
ReMark Posted January 14, 2009 Posted January 14, 2009 AutoCAD settings that affect 3D output. DISPSILH – Display Sihouette This setting affects the results of the Hide command. A setting of 0 displays tessellation lines. A setting of 1 suppresses tessellation lines. FACETRATIO – Quality of Rendered & Shaded Models This setting affects mesh density thus controlling the aspect ratio of faceting for cylindrical and conic solids. The settings are 0 and 1. A setting of 1 will increase the density of the mesh. FACETRES – Rendered Object Smoothness This setting affects both rendering and hide results. The default setting is 0.5. The max setting is 10. A lower setting results in a quicker render time but rounded edges will appear as a series of straight segments. A higher setting results in a longer render time but rounded edges will appear much smoother. ISOLINES – Contour lines per surface This setting affects the wireframe view but not the Hide or Render commands. Settings can range from 0 to 2047. The default setting is 4. SPLINESEGS – Segments in a Polyline Curve This setting controls the number of segments in a polyline curve. The settings range from 0 to 32767 with the default being 8. The higher the setting the smoother the appearance is of a rendered curve. Quote
CADDict Posted January 14, 2009 Posted January 14, 2009 To get rid of those lines, use the DISPSILH command. Set it to 0 like ReMark's post says. Quote
vinod Posted January 14, 2009 Author Posted January 14, 2009 AutoCAD settings that affect 3D output. DISPSILH – Display Sihouette This setting affects the results of the Hide command. A setting of 0 displays tessellation lines. A setting of 1 suppresses tessellation lines. FACETRES – Rendered Object Smoothness This setting affects both rendering and hide results. The default setting is 0.5. The max setting is 10. A lower setting results in a quicker render time but rounded edges will appear as a series of straight segments. A higher setting results in a longer render time but rounded edges will appear much smoother. ISOLINES – Contour lines per surface This setting affects the wireframe view but not the Hide or Render commands. Settings can range from 0 to 2047. The default setting is 4. SPLINESEGS – Segments in a Polyline Curve This setting controls the number of segments in a polyline curve. The settings range from 0 to 32767 with the default being 8. The higher the setting the smoother the appearance is of a rendered curve. To get rid of those lines, use the DISPSILH command. Set it to 0 like ReMark's post says. I got what I want.. Thanks a lot! Quote
ReMark Posted January 14, 2009 Posted January 14, 2009 You're welcomed Vinod. Might want to print and post for future reference. Quote
vinod Posted January 14, 2009 Author Posted January 14, 2009 You're welcomed Vinod. Might want to print and post for future reference. I already printed & filed.. A nice help! Quote
