07lodgeT Posted July 4, 2017 Posted July 4, 2017 Hello, Is there a way of searching across a number of AutoCAD files for files containing particular text? This used to be possible in Windows XP, but does now not work in Windows 7 annoyingly. We have thousands of DWG files that have been drawn up over the past 20 years and to be able to search for a particular text string in a file would be hugely beneficial, such as part numbers and job numbers etc. We are running Windows 7 and AutoCAD 2018 LT. Can this be done with our current setup, or is there a another program we could use? I believe Autodesk Content Explorer used to serve this function, but has now been discontinued. Your help would be greatly appreciated. Quote
Dadgad Posted July 4, 2017 Posted July 4, 2017 (edited) Welcome to CADTutor 07lodgeT. When in doubt, check Lee Mac out. http://www.lee-mac.com/bfind.html Thanks Lee! Better yet, before you are in doubt, check out his incredible offerings preemptively. Whoops, you are using LT, no lisp! Do you have access to a non LT machine on which you could use this? Edited July 4, 2017 by Dadgad Quote
07lodgeT Posted July 4, 2017 Author Posted July 4, 2017 Dadgad said: Welcome to CADTutor 07lodgeT. When in doubt, check Lee Mac out. http://www.lee-mac.com/bfind.html Thanks Lee! Better yet, before you are in doubt, check out his incredible offerings preemptively. Thanks for that, unfortunately Autocad LT doesn't support LISP or VB Quote
BIGAL Posted July 6, 2017 Posted July 6, 2017 "FINDSTR" is for text files it is a Windows command line operating system option. There may be a binary version. Else you will need a compiled .net version of something like bfind. Findstr VLA *.lsp Quote
SLW210 Posted July 10, 2017 Posted July 10, 2017 There is a DwgSearch tool in DotSoft's ToolPac available at Dotsoft.com. Perhaps you can contact them to get just the DwgSearch function. Quote
