I have received a survey with this type of points. I would like to know how from civil 2017 I can include it in an already created surface.
Thank you
Point.dwg
This is real quick and dirty lisp code but matches your dwg. Makes new Autocad "points" then use the option "Add Drawing objects, Points" to merge into an existing surface. It can do with a bit of refinement if its to be used often.
(defun makepts ( / ss pt x)
(setq ss (ssget (list(cons 0 "insert")(cons 8 "V-NODE")) )) ; a block on layer "V-node"
(setq ent (assoc 10 (entget (ssname ss (setq x (- x 1)))))) ; insertion point in 3d
(setq pt (list (cadr ent)(caddr ent)(cadddr ent)))
(command "point" pt)
(makepts)
