My last notebook computer died and my new one is running Windows 10.
I have AutoCAD 2011 however the toolbars are so small that I almost need a microscope to see them.
My question: How can I make the toolbars larger?
Thank you,
Neville
Thanks Welldriller that is sorted.
However a lot of my menus/command lists etc when I open them look like a stack of pages where each page covers half the heading of the previous page.
Do you have any idea how to fix that?
Kind regards,
Neville
No at this time i do not but if you could post a screen shot of what it is doing i am sure that before long someone will come up with a solution.
Thanks Welldriller.
I have taken the screenshot but I don't know how to add it to my post!
Regards,
Neville
Kind regards,
Neville
2011 is not supported by Win 10. These sound like compatibility issues. I had similar problems with 2009 that I could never fix.
How do I upload a screenshot to this thread?
Thank you for the link.
I think I have uploaded a screenshot of my problem.
However if Win10 is not compatible with my AutoCAD 2011 and nobody has any ideas on a fix I'm not sure what I can do!
Kind regards,
Neville
That seemed to work thank you Dana. This shows my issue with all the menus practically unreadable.
Thank's Dana W i had not checked into that.
You can check your AutoDesk account download section for any hot fixes, but I am pretty sure the only retro hot fix is for AutoCad 2016 to Win 10.
There are programs available that can run a virtual Win 7 OS for older software that will get you by, but I have not looked into any of them. Since I lease AutoCad, I simply update my version when I need to.
The problem here is that your new laptop has a 4K monitor. AutoCAD did not have even minimal 4K support until a 2017 update.
There are some adjustments you can make but none will clear up all the issues. I think you need to lower the screen resolution and keep text scaling below 150%. Plenty of more definitive information can be found over at the Autodesk forums on this.
G'day RobDraw,
Mate, you have solved my problem.
Thank you.
I changed the settings to text scaling 125 and the resolution to 1920x1080 and it works properly.
Kind regards,
Neville
