avagorn Posted June 15, 2017 Posted June 15, 2017 Hello, I would like to write a procedure (function) which will show how many hatch areas are on the drawing. For example: I have drawing which has 3 objects (2 rectangulars and 1 circle - all in layer 0. 1 rectangular and 1 circle is hatch. So when I will start the function it will show message about 2 hatch objects. Quote
maratovich Posted June 15, 2017 Posted June 15, 2017 Try it Public Sub HatchCount() 'On Error Resume Next '-------------------+ Dim ObjSS Dim SSitems Dim FilterType(0) As Integer Dim FilterData(0) As Variant '----------------------------------------------------------------------------------+ Set ObjSS = ThisDrawing.SelectionSets For Each SSitems In ObjSS If SSitems.Name = "Nabor" Then ThisDrawing.SelectionSets.Item("Nabor").Delete Exit For End If Next Set SSitems = ThisDrawing.SelectionSets.Add("Nabor") '----------------------------------------------------------------------------------+ FilterType(0) = 0 FilterData(0) = "HATCH" SSitems.Select acSelectionSetAll, , , FilterType, FilterData 'or 'SSitems.SelectOnScreen FilterType, FilterData '----------------------------------------------------------------------------------+ If Err Then Err.Clear: Exit Sub If SSitems.Count - 1 = -1 Then MsgBox "Selection empty !", vbExclamation Exit Sub End If '----------------------------------------------------------------------------------+ MsgBox "HATCH - " & SSitems.Count, vbSystemModal + vbInformation '----------------------------------------------------------------------------------+ End Sub Quote
avagorn Posted June 15, 2017 Author Posted June 15, 2017 Thank you. It works but I see some issues. For example: 1. I drew 3 circles 2. Next I went to Hatch Creation and made hatch in 2 circles 3. Finally I closed Hatch Creation Then the function will say about 1 hatch object. But if I change actions: 1. I drew 3 circles 2. Next I went to Hatch Creation and made hatch in first circle 3. I closed Hatch Creation 4. I went to Hatch Creation again and made hatch in second circle 5. I closed Hatch Creation Then the function will say about 2 hatch objects and this is correct result. Do you have any ideas how to improve this function? Also if it is not a problem I would like to ask about help in: - make this function also let the user to change hatch pattern to solid with possibility to choose color. Quote
maratovich Posted June 15, 2017 Posted June 15, 2017 Do you have any ideas how to improve this function? No. Only individual hatching. Otherwise it does not work. - make this function also let the user to change hatch pattern to solid with possibility to choose color. It is necessary - or know exactly what type of fill and color - or make a form that will select the color you want. Quote
avagorn Posted June 15, 2017 Author Posted June 15, 2017 It is necessary - or know exactly what type of fill and color - or make a form that will select the color you want. - pattern type: ANSI31, Hatch Pattern Scale 10 - form with colors will be great Quote
maratovich Posted June 18, 2017 Posted June 18, 2017 Public Sub HatchCount() 'On Error Resume Next '-------------------+ Dim ObjSS Dim SSitems Dim FilterType(0) As Integer Dim FilterData(0) As Variant Dim HatchItem As AcadHatch Dim color As AcadAcCmColor Dim Version As String '----------------------------------------------------------------------------------+ Set ObjSS = ThisDrawing.SelectionSets For Each SSitems In ObjSS If SSitems.Name = "Nabor" Then ThisDrawing.SelectionSets.Item("Nabor").Delete Exit For End If Next Set SSitems = ThisDrawing.SelectionSets.Add("Nabor") '----------------------------------------------------------------------------------+ FilterType(0) = 0 FilterData(0) = "HATCH" SSitems.Select acSelectionSetAll, , , FilterType, FilterData 'or 'SSitems.SelectOnScreen FilterType, FilterData '----------------------------------------------------------------------------------+ If Err Then Err.Clear: Exit Sub If SSitems.Count - 1 = -1 Then MsgBox "Selection empty !", vbExclamation Exit Sub End If '----------------------------------------------------------------------------------+ MsgBox "HATCH - " & SSitems.Count, vbSystemModal + vbInformation '----------------------------------------------------------------------------------+ Version = Left(ThisDrawing.GetVariable("ACADVER"), 2) Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Version) color.SetRGB 80, 100, 244 '----------------------------------------------------------------------------------+ For Each HatchItem In SSitems HatchItem.SetPattern acHatchPatternTypePreDefined, "ANSI31" HatchItem.PatternScale = 10 HatchItem.TrueColor = color HatchItem.Evaluate Next '----------------------------------------------------------------------------------+ MsgBox "Ok!", vbSystemModal + vbInformation '----------------------------------------------------------------------------------+ End Sub Quote
avagorn Posted July 9, 2017 Author Posted July 9, 2017 Sorry for late reply. The procedure works good. Thank you very much for help. Quote
BIGAL Posted July 10, 2017 Posted July 10, 2017 You can get at the number of individual hatches that make 1 bigger hatch pattern if you dump a hatch you will see the variable "numerof loops" (vl-load-com) (defun hatchnum ( / x num ss tot) (setq ss (ssget (list (cons 0 "hatch")))) (setq num (sslength ss)) (setq tot 0) (repeat (setq x (sslength ss)) (setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (setq tot (+ (vla-get-numberofloops obj) tot )) ) (alert (strcat "There is " (rtos num 2 0) "hatches\n\nMade up of " (rtos tot 2 ) " sections")) ) (hatchnum) Quote
