Currahee Posted June 13, 2017 Posted June 13, 2017 (edited) I have a hard time placing a part in assembly when there is nothing to place a constraint onto. For instance look at this picture for example. Usually I would have to put a small hole in each part for an index to place it exactly where I want it. How can I use the "Join" command instead of / or with the "Constraint" command to put a part in a place without the index. I am sure there is a shorter and better way Edited June 13, 2017 by Currahee Quote
czc Posted June 14, 2017 Posted June 14, 2017 Why don't you use the workplanes of the circular part to place it? Quote
shift1313 Posted June 17, 2017 Posted June 17, 2017 how are they aligned if they were real parts? You can use sketches, axis etc to help align, or workplanes as czc said. But in general when working with assemblies i try to think about how you would put them together physically. Quote
vertical horizons Posted June 26, 2017 Posted June 26, 2017 I agree with czc. Use the mid plane of each part. Quote
