Hi to All
I'm new working with Autocadd 360, I have bought my image in, found the area that I'm working in, did my work,went to a layout tab and lost my image went back to model space and the image is gone. tried to regenerate the drawing, high lite the image frame changed property from very fine to fine and back. no image is there something that I'm missing.
brl2008
Whats "bought in"?
Do you use some kind of Map / gis service?
There is a great tool for importing imagery called "IRT", it will download / xref and save your images on your local drive.
thank for the answer. the image i'm bring in is a google earth image with a town location or lat/long coord.
My guess is, the image is from the Web or some other network. Sometimes a network redefines the IP addresses of its nodes. Some networks give out new IP addresses when the nodes log on (my cable hookup at home does it). In other words, if the image is stored remotely and the IP address changes, your link to it breaks. If the image will be a permanent part of your drawing, you should download a copy, as halam suggests.
If that's not your problem, please provide more information. Where is the image stored? What mechanism/command did you use to put it in your drawing?
