Autocad 2018 lt zoom pan commends are very slow
Dear,
I have problem with autocad 2018 lt zoom, pan and commends also getting very very slow.. got very trouble have any solution in any settings .. ??
guide me..
Same here. Everything seems to be getting slow.
Frustrations about freezing sessions when switching opened files here
CAD64 has mentioned a couple of things that could slow Autocad down. xrefs, dynamic blocks and network problems are a few others.
Is this something new with 2018 that didn't occur in earlier releases?
Is your computer spec'd for 2018?
2018 running fine here. Seems aster than 2017 for me, and I have a lame computer. I do have stuttering zooms and pans, but they are not slow, just jerky. I have an on board video processor.
no image and pdf file in this cad
my computer is windows8
1TP hd
8GB RAM
2GB graphic
and mu disk "c" space for 64GB space
WHEN I OPEN MY CAD I GOT THIS MESSAGE (ATTACHED)
Whenever you see a specific error message like this the first thing you should do is conduct an Internet search using the exact wording. If you had done that in this case you would have found a link to this AutoDesk knowledge-based article describing the cause of the problem and the solution.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-The-object-cannot-be-resolved-or-value-limit-has-been-exceeded-in-AutoCAD.html
