Hi
Autocad 12, 64Bit
When trying to Export Layout to Model, I get the Error window (See attachment): JIT Debugging Error.
I did evrything: reinstall, updating the grahic card driver, updating Microsoft .net,
nothing works.
Thanks fo any help
Found this online re: JIT Debugging error and AutoCAD.
Just-In-Time (JIT) errors are typically related to the issues with Microsoft .NET Framework, which is installed as prerequisite during the installation of AutoCAD.
Solution:
You may see this error if the Microsoft .NET Framework component is not installed on your computer, or is outdated or damaged. The error can be fixed by removing and reinstalling the .NET Framework.
