thanhdattdk Posted May 30, 2017 Posted May 30, 2017 Hello everbody. I want to Calculate block area in closed area. I hope everybody help me. Thank you all read my thread. Quote
rlx Posted May 30, 2017 Posted May 30, 2017 (edited) Hi thanhdattdk, found this link : http://www.cadtutor.net/forum/archive/index.php/t-50016.html Maybe someone else has a stripped down version but command c:HatL pretty much does the job although you might have to do some tweaking. Purpose of this forum besides shopping is also learning gr.R. Edited June 1, 2017 by rlx Quote
welldriller Posted May 30, 2017 Posted May 30, 2017 Can't remember how to do it in AutoCad but in Draftsight (free version) here is how it is done. click on TOOLS at the top click on INQUIRY in the drop down menu click on GET AREA in pop out menu LEFT click on all 4 corners of the hatched area RIGHT click the mouse on the COMMAND LINE it will give you the AREA & PERIMETER Hope this will help Quote
BKT Posted May 30, 2017 Posted May 30, 2017 It looks as if you've created a hatch to show the area needed. Select the hatch and check in Properties. It should show the area there. You can also use the AREA -> OBJECT command. Quote
thanhdattdk Posted May 31, 2017 Author Posted May 31, 2017 thank you very much. my threat http://www.cadtutor.net/forum/showthread.php?100800-Table-statistical-area-of-home Quote
