Fieldmouse Posted May 20, 2017 Share Posted May 20, 2017 I am confused, I have set my layers, plotted my paper, set my units, text styles, and made two blocks, as directed. Now I am stuck on how to enter my POB and benchmark coordinates to begin my project. Can anyone please give me some assistance? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 20, 2017 Share Posted May 20, 2017 Are you a student? Is this the Penn Foster Oleson Village project? If so, you might want to take a look at the Student Projects section. There are several threads dedicated to this project that will no doubt be useful to you. http://www.cadtutor.net/forum/forumdisplay.php?73-Student-Project-Questions Quote Link to comment Share on other sites More sharing options...
Fieldmouse Posted May 21, 2017 Author Share Posted May 21, 2017 Okay, thanks for the help! Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 21, 2017 Share Posted May 21, 2017 The coordinates can be entered at the command line when you are prompted for a start point and the next point. X/Y coordinate separated by a comma then hit the Enter key. Quote Link to comment Share on other sites More sharing options...
Irene Posted July 16, 2018 Share Posted July 16, 2018 I am working on a Penn Foster project ( Oleson Village) I have looked through so many post and see a lot of people with the same problem that I am having and I still have not found the solution. I have tried to enter the first simple line coordinates over and over! I get no where.I set up the parameters to PF specs . Decimal, 0.00, Surveyors Units, N 0d00'00"E, and scale feet. When I enter my first coordinate @113.66 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 18, 2018 Share Posted July 18, 2018 The @ symbol gives you a relative coordinate, that is, it uses the previous point as the beginning and measures from there. If there is no previous coordinate, there's nowhere to work from. For the first point, omit the @ symbol and use an X,Y coordinate, probably your benchmark/POB. From then on you can use relative coordinates. AutoCAD remembers your last point, so you can resume your drawing by pressing space/enter to begin from the end of the last line segment. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 18, 2018 Share Posted July 18, 2018 This: @113.66 This is what coordinates would look like: Later on in the project you'll be given coordinates to enter to locate trees on the property. Quote Link to comment Share on other sites More sharing options...
