pmxcad Posted April 1, 2022 Posted April 1, 2022 Good afternoon RLX. It's been a while since I've been on cadtutor. I was looking for a lisp similar to your DCL/lisp. The routine is almost perfect. Is it possible to make some additions? Is it possible to do that in that txt file? Such as: All specified blocks. Path to the drawings. Location. Drawingname filter like "*SC2*.dwg". Take over Attribute position. Take over Attribute alignment. And the ability to apply an external lisp/script to any drawing. This is more because I am using syn.lsp to attsync the attributes without moving the attributes. It's a decent list but I don't know if it's possible. ARTICLECODE,ARTICLECODE,ARTICLECODE MONTAGE,RECEPTCODE,RECEPTCODE CID,TEXT1,TEXT1 TEXT1,TEXT2,TEXT2 RUIMTECODE,RUIMTECODE,RUIMTECODE NETWERK,NETWERK,NETWERK DEUR_NUMMER,DEUR_NUMMER,DEUR_NUMMER KAST_NUMMER,KAST_NUMMER,KAST_NUMMER WAARDEKAST_NUMMER,WAARDEKAST_NUMMER,WAARDEKAST_NUMMER BESTAAND_OVERNAME,BESTAAND_OVERNAME,BESTAAND_OVERNAME ARTICLECODE_01,ARTICLECODE_01,ARTICLECODE_01 ARTICLECODE_02,ARTICLECODE_02,ARTICLECODE_02 ARTICLECODE_03,ARTICLECODE_03,ARTICLECODE_03 ARTICLECODE_04,ARTICLECODE_04,ARTICLECODE_04 ARTICLECODE_05,ARTICLECODE_05,ARTICLECODE_05 ARTICLECODE_06,ARTICLECODE_06,ARTICLECODE_06 ARTICLECODE_07,ARTICLECODE_07,ARTICLECODE_07 ARTICLECODE_08,ARTICLECODE_08,ARTICLECODE_08 ARTICLECODE_09,ARTICLECODE_09,ARTICLECODE_09 TEXT2,TEXT3,TEXT3 SYMBOOL_TOEVOEGING,SYMBOOL_TOEVOEGING,SYMBOOL_TOEVOEGING DETECTIE_ZONE,DETECTIE_ZONE,DETECTIE_ZONE WG_TYPE,WG_TYPE,WG_TYPE WG_NAAM,WG_NAAM,WG_NAAM WG_SENSORNR,WG_SENSORNR,WG_SENSORNR WG_SENSORTYPE,WG_SENSORTYPE,WG_SENSORTYPE WG_LOCATIE,WG_LOCATIE,WG_LOCATIE WG_GEBIEDNAAM,WG_GEBIEDNAAM,WG_GEBIEDNAAM WG_ANIMATIEKLEUR,WG_ANIMATIEKLEUR,WG_ANIMATIEKLEUR WG_ANIMATIESCHEMA,WG_ANIMATIESCHEMA,WG_ANIMATIESCHEMA #RLXBLK-MATCH-BLK-COL=1 #RLXBLK-MATCH-BLK-LAY=1 #RLXBLK-MATCH-BLK-LIN=1 #RLXBLK-MATCH-BLK-ROT=1 #RLXBLK-MATCH-BLK-SCL=1 #RLXBLK-MATCH-BLK-TRANSP=1 #RLXBLK-MATCH-BLK-VIS=0 #RLXBLK-MATCH-ATT-COL=1 #RLXBLK-MATCH-ATT-HGT=1 #RLXBLK-MATCH-ATT-INS=1 #RLXBLK-MATCH-ATT-LAY=1 #RLXBLK-MATCH-ATT-OBL=1 #RLXBLK-MATCH-ATT-ROT=1 #RLXBLK-MATCH-ATT-STL=1 #RLXBLK-MATCH-ATT-TRANSP=1 #RLXBLK-MATCH-ATT-VAL=1 #RLXBLK-MATCH-ATT-WID=1 #RLXBLK-FIND-BLK-COL= #RLXBLK-FIND-BLK-LAY= #RLXBLK-FIND-BLK-LIN= #RLXBLK-FIND-BLK-ROT= #RLXBLK-FIND-BLK-SCL= #RLXBLK-FIND-BLK-TRANSP= #RLXBLK-FIND-BLK-VIS= #RLXBLK-FIND-ATT-COL= #RLXBLK-FIND-ATT-HGT= #RLXBLK-FIND-ATT-LAY= #RLXBLK-FIND-ATT-OBL= #RLXBLK-FIND-ATT-ROT= #RLXBLK-FIND-ATT-STL= #RLXBLK-FIND-ATT-TRANSP= #RLXBLK-FIND-ATT-WID= #RLXBLK-SET-BLK-COL=256 #RLXBLK-SET-BLK-LAY= #RLXBLK-SET-BLK-LIN= #RLXBLK-SET-BLK-ROT= #RLXBLK-SET-BLK-SCL= #RLXBLK-SET-BLK-TRANSP=ByBlock #RLXBLK-SET-BLK-VIS= #RLXBLK-SET-ATT-COL=256 #RLXBLK-SET-ATT-HGT= #RLXBLK-SET-ATT-LAY= #RLXBLK-SET-ATT-OBL= #RLXBLK-SET-ATT-ROT= #RLXBLK-SET-ATT-STL= #RLXBLK-SET-ATT-TRANSP=ByBlock #RLXBLK-SET-ATT-WID= #RLXBLK-USE-EXTENTS=0 #RLXBLK-USE-WINDOW=0 #RLXBLK-USER-RANGE=1 #RLXBLK-RANGECORNERPOINT1= #RLXBLK-RANGECORNERPOINT2= #RLXBLK-SETPROPERTYMODE=0 #RLXBLK-FINDPROPERTYMODE=1 #RLXBLK-OLDBLOCKNAME=U00061 #RLXBLK-NEWBLOCKNAME=P:\05- Autocad\STABICAD NL\Symbols\Electrical\NEW BLOCKS\U00065.dwg #RLXBLK-USEEXTERNALBLOCKLIST=1 #RLXBLK-EXTERNALBLOCKSOURCE=P:\05- Autocad\STABICAD NL\Symbols\Electrical\NEW BLOCKS\U00065.dwg #RLXBLK-DATAFILENAME=P:\05- Autocad\Scripts\tempunnamed.all #RLXBLK-REDEFINE=Redefine Block #RLXBLK-OLDVISIBILITYNAME= #RLXBLK-NEWVISIBILITYNAME= Thank you in advance, Jaap Quote
Spiida Posted January 23 Posted January 23 Hello Auriez-vous la dernière version du programme ? car les liens ne marche plus... Merci ! Quote
SLW210 Posted January 24 Posted January 24 On 1/23/2025 at 2:39 PM, Spiida said: Hello Auriez-vous la dernière version du programme ? car les liens ne marche plus... Merci ! They work fine for me. Could they be blocked at your work? Quote
