Is there an C sharp, VB.net or lisp routine that is equivlent
to the Attipedit command?
The AttipEdit command allows a user to select an attribute
in a block reference and directly edit it.
Most C sharp vb.net or lisp routines has the user to
select the block and then the program extracts the attribute
for a block defination.
Thank you,
Nentsel you can pick an object like an attribute, (setq obj (entget (car (nentsel)))) just pick attribute. There should be a method in .Net etc.
