SlalomeVr Posted May 11, 2017 Posted May 11, 2017 Hello, I try to modify this lisp to draw only vertical (or horizontal) lines (defun c:foo (/ selection pline sscount objpline inspoint intpoint entity) (if (not (setq selection (ssget "_I" '((0 . "CIRCLE,INSERT"))))) (progn (prompt "\nSelect circles: ") (setq selection (ssget '((0 . "CIRCLE,INSERT")))) ) ) (setq pline (entsel "\nSelect polyline: ")) (if (and pline (setq objpline (vlax-ename->vla-object (car pline))) ) (repeat (setq sscount (sslength selection)) (setq entity (entget (ssname selection (setq sscount (1- sscount)))) inspoint (cdr (assoc 10 entity)); both center of Circle and insertion pt of Block intpoint (vlax-curve-getclosestpointto objpline inspoint) ) (if intpoint (command "_.line" "non" inspoint "non" intpoint "") ) ) ) ) I tried to modify this line intpoint (vlax-curve-getclosestpointto objpline inspoint) to intpoint (vlax-curve-getClosestPointToProjection objpline inspoint '(0 1 0))) But I have a error, i think it misses the Z coordinates of the block can you help me? thank you in advance Quote
SlalomeVr Posted May 12, 2017 Author Posted May 12, 2017 Hello BIGAL Here is a dwg with explanations The aim being subsequently to transform the polylines into dimensions exemple.dwg Quote
Roy_043 Posted May 12, 2017 Posted May 12, 2017 Try: (defun KGA_Conv_Pickset_To_ObjectList (ss / i ret) (if ss (repeat (setq i (sslength ss)) (setq ret (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) ret)) ) ) ) (defun KGA_List_Divide_3 (lst / ret) (repeat (/ (length lst) 3) (setq ret (cons (list (car lst) (cadr lst) (caddr lst)) ret)) (setq lst (cdddr lst)) ) (reverse ret) ) (defun KGA_Sys_ObjectOwner (obj) (vla-objectidtoobject (vla-get-database obj) (vla-get-ownerid obj)) ) (defun LineToCurve (sta vec curve / end line ptLst) (setq line (vla-addline (KGA_Sys_ObjectOwner curve) (vlax-3d-point sta) (vlax-3d-point (mapcar '+ sta vec)) ) ) (if (setq ptLst (KGA_List_Divide_3 (vlax-invoke line 'intersectwith curve acextendthisentity))) (progn (setq end (car ptLst)) (foreach pt (cdr ptLst) (if (< (distance sta pt) (distance sta end)) (setq end pt) ) ) (vla-put-endpoint line (vlax-3d-point end)) line ) (progn (vla-delete line) nil ) ) ) (defun c:LinesToCurve ( / curve doc pt1 pt2 ss vec) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) (vla-startundomark doc) (if (and (setq curve (car (entsel "\nSelect curve: "))) (setq curve (vlax-ename->vla-object curve)) (princ "\nSelect blocks: ") (setq ss (KGA_Conv_Pickset_To_ObjectList (ssget '((0 . "INSERT"))))) (setq pt1 (getpoint "\nFirst point for direction: ")) (setq pt2 (getpoint pt1 "\nSecond point for direction: ")) ) (progn (setq vec (trans (mapcar '- pt2 pt1) 1 0 T)) (foreach blk ss (LineToCurve (vlax-get blk 'insertionpoint) vec curve) ) ) ) (vla-endundomark doc) (princ) ) 1 Quote
SlalomeVr Posted May 12, 2017 Author Posted May 12, 2017 Thank's Roy_043 i will adapt my lisp with this method Quote
