I have a 3dpoly from previous my post (Thank Marko_ribar)
I like this 3D polyline have a longitudinal profiles
Road Plan 4.dwg
You have Civ3d ? Just explode the 3dplines and make a surface using "drawing objects Lines" long section will then come out. The green line is your profile from your dwg, took maybe 5 minutes.
dear BIGAL
I also agree with you, but I'll try to explain with poor English language
In the company that I'm working on it, there are several sections, one of which is the architecture section
The personnel in this section will work with the topography have difficulty
Not only the topography but also have problems with the "Z" value
But locating designed buildings on the topographic maps need to have traced the longitudinal profiles
They usually refer to the civil section
I suggest to fix this problem long ago, installing a land development or civil3d and I teach it by myself However, this section was not faced with personnel
I tried to solve the problem with lisp them is that I got a successful
That on the track designed by them on the topography plan I create 3dpolyline and draw longitudinal profiles give the delivery
Of course, as long as the problem raised in my previous post I came into
The following two previous posts I have problems
if possible guide me
in end of the Attachments lisp file (by: Marko_ribar) and after the run script was created
program can not continue.
Road Plan 3.dwg
Create Profile from 3dpoly.lsp
Edited by reza
Reza do not double post you should have added this to your 1st post. Admin will fix up.
I am sure Marko will have a look and respond.
Marko I tried code and after "INT" locked up error was ":call back entry". Totally restarted Autocad and at prompt selected some lwplines with a Z value then noticed that selection set was 0 items ? What am I doing wrong ?
Hi Dear BIGAL
Thank you very much for mentioning right and left.
n the next post I'll follow this hint.
my dear friends :
I met this morning with a problem in using the program
in attachment drawing file, Graphic profiles drawn wrong in some places.
new block.dwg
  • 2 weeks later...
@reza, there is no way you can get Z elevation of vertices of planar LWPOLYLINE that are to be transformed to 3d poly... Instead I suggest that you try to use just intersections with contours...
(defun c:flw23pel ;fencelwpoly23dpolyelevations
 ( / *error* bbucs ucsf osm cec ss1 ss2 i lw pl sss ssl sspl e )
 (vl-load-com)
 (defun *error* ( msg )
   (if ucsf
     (command "_.UCS" "_P")
   (command "_.ZOOM" "_P")
   (if osm
     (setvar 'osmode osm)
   (if cec
     (setvar 'cecolor cec)
   (if msg
     (prompt msg)
 (defun bbucs ( ss / UCS2WCSMatrix WCS2UCSMatrix n ent minpt maxpt minptlst maxptlst minptbbx minptbby minptbbz minptbb maxptbbx maxptbby maxptbbz maxptbb )
   (vl-load-com)
   ;; Doug C. Broad, Jr.
   ;; can be used with vla-transformby to
   ;; transform objects from the UCS to the WCS
   (defun UCS2WCSMatrix ()
     (vlax-tmatrix
       (append
         (mapcar
          '(lambda (vector origin)
           (append (trans vector 1 0 t) (list origin))
         (list '(1 0 0) '(0 1 0) '(0 0 1))
         (trans '(0 0 0) 0 1)
         (list '(0 0 0 1))
   ;; transform objects from the WCS to the UCS
   (defun WCS2UCSMatrix ()
     (vlax-tmatrix
       (append
         (mapcar
           (append (trans vector 0 1 t) (list origin))
         (trans '(0 0 0) 1 0)
         (list '(0 0 0 1))
   (if ss
       (repeat (setq n (sslength ss))
         (setq ent (ssname ss (setq n (1- n))))
         (vla-TransformBy (vlax-ename->vla-object ent) (UCS2WCSMatrix))
         (vla-getboundingbox (vlax-ename->vla-object ent) 'minpoint 'maxpoint)
         (vla-TransformBy (vlax-ename->vla-object ent) (WCS2UCSMatrix))
         (setq minpt (vlax-safearray->list minpoint))
         (setq maxpt (vlax-safearray->list maxpoint))
         (setq minptlst (cons minpt minptlst))
         (setq maxptlst (cons maxpt maxptlst))
       (setq minptbbx (caar (vl-sort minptlst '(lambda (a b) (< (car a) (car b))))))
       (setq minptbby (cadar (vl-sort minptlst '(lambda (a b) (< (cadr a) (cadr b))))))
       (setq minptbbz (caddar (vl-sort minptlst '(lambda (a b) (< (caddr a) (caddr b))))))
       (setq maxptbbx (caar (vl-sort maxptlst '(lambda (a b) (> (car a) (car b))))))
       (setq maxptbby (cadar (vl-sort maxptlst '(lambda (a b) (> (cadr a) (cadr b))))))
       (setq maxptbbz (caddar (vl-sort maxptlst '(lambda (a b) (> (caddr a) (caddr b))))))
       (setq minptbb (list minptbbx minptbby minptbbz))
       (setq maxptbb (list maxptbbx maxptbby maxptbbz))
   (list minptbb maxptbb)
 (if (= 0 (getvar 'worlducs))
     (command "_.UCS" "_W")
     (command "_.PLAN" "")
     (setq ucsf t)
 (setq osm (getvar 'osmode))
 (setvar 'osmode 0)
 (setq cec (getvar 'cecolor))
 (setvar 'cecolor "3")
 (prompt "\nSelect OPEN \"STRAIGHT\" LWPOLYLINES that lie in plane parallel to WCS - PROJECTION LWPOLYLINES (NOT ELEVATION)...")
 (setq ss1 (ssget (list '(0 . "LWPOLYLINE") '(-4 . "<or") '(70 . 0) '(70 . 128) '(-4 . "or>") '(-4 . "<or") '(210 0.0 0.0 1.0) '(210 0.0 0.0 -1.0) '(-4 . "or>") '(-4 . "<not") '(-4 . "<>") '(42 . 0.0) '(-4 . "not>"))))
 (while (or
          (not ss1)
          (vl-every '(lambda ( x ) (not (equal (caddar (bbucs (ssadd x))) (caddr (cadr (bbucs (ssadd x)))) 1e-6))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss1))))
   (prompt "\nEmpty sel.set... Please reselect again...")
 (prompt "\nSelect LWPOLYLINES that lie in plane parallel to WCS - ELEVATION LWPOLYLINES (NOT PROJECTION)...")
 (setq ss2 (ssget (list '(0 . "LWPOLYLINE") '(-4 . "<or") '(210 0.0 0.0 1.0) '(210 0.0 0.0 -1.0) '(-4 . "or>"))))
 (while (not ss2)
 (repeat (setq i (sslength ss1))
   (setq lw (ssname ss1 (setq i (1- i))))
   (setq pl (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= (car x) 10)) (entget lw))))
   (setq sss (ssget "_F" pl (list '(0 . "LWPOLYLINE") '(-4 . "<or") '(210 0.0 0.0 1.0) '(210 0.0 0.0 -1.0) '(-4 . "or>"))))
   (setq ssl (ssnamex sss))
   (setq ssl (vl-remove-if '(lambda ( x ) (eq (cadr x) lw)) ssl))
   (setq sspl (mapcar 'cadr (apply 'append (mapcar '(lambda ( x ) (vl-remove-if-not 'listp x)) ssl))))
   (setq sspl (vl-sort sspl '(lambda ( a b ) (< (vlax-curve-getparamatpoint lw (vlax-curve-getclosestpointto lw (list (car a) (cadr a) (cdr (assoc 38 (entget lw)))))) (vlax-curve-getparamatpoint lw (vlax-curve-getclosestpointto lw (list (car b) (cadr b) (cdr (assoc 38 (entget lw))))))))))
   (command "_.3DPOLY")
   (foreach p sspl
     (if (vl-some '(lambda ( x ) (if (vlax-curve-getparamatpoint x (list (car p) (cadr p) (cdr (assoc 38 (entget x))))) (setq e x))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss2))))
       (command "_non" (list (car p) (cadr p) (cdr (assoc 38 (entget e)))))
   (command "")
 (*error* nil)
HTH., M.R.
