johanlang Posted May 4, 2017 Posted May 4, 2017 Hi All, In the drawing, there are a lot of element in diffrent colors and all are in layer 0. How do I do a vba macro to move all red elements in the drawing to one layer, for example to an existing layer named red? I need a vba macro which not require any manual input, that dialouge boxes open for user select, etc... Quote
spiff88 Posted May 4, 2017 Posted May 4, 2017 (edited) This VBA code will work from within Excel VBE as long as you set the References to the AutoCAD 20xx Type Library for your version of AutoCAD. To use, open the DWG, then run the code in the Excel VBE. The code loops through all objects in model spaces, the IF-THEN checks the color, and then changes the layer if the color = 1 (red). Sub MoveRedObjects() Dim objApp As AcadApplication Dim objDoc As AcadDocument Set objApp = GetObject(, "AutoCAD.Application") Set objDoc = objApp.ActiveDocument For Each obj In objDoc.ModelSpace If obj.Color = 1 Then obj.Layer = "red" End If Next End Sub Hopefully this does what you need. Edited May 5, 2017 by spiff88 Quote
BIGAL Posted May 5, 2017 Posted May 5, 2017 spiff88 probably a good idea to make the new layer Red_layer_name before doing object collection so no crash on layer does not exist. Johanlang an extra question do you have blocks that are all red ? Quote
RICVBA Posted August 29, 2017 Posted August 29, 2017 You could narrow down selectionset to filter elements whose color is Red only Sub MoveRedObjects2() Dim redsSset As AcadSelectionSet Dim acEnt As AcadEntity If GetColoredEntities(redsSset, 1) Then ThisDrawing.Layers.Add ("Red") For Each acEnt in entsSet acEnt.Layer = "Red" Next End If End Sub Function GetColoredEntities(redsSset As AcadSelectionSet, color As Integer) Dim gpCode(0 to 0) As Integer Dim dataValue(0 to 0) As Variant gpCode(0) = 62: dataValue(0) = 1 'red color On Error Resume Next Set redsSset = ThisDrawing.SelectionSets.Add("Reds") On Error GoTo 0 If redsSset Is Nothing Then Set redsSset = ThisDrawing.SelectionSets.Item("Reds") With redsSset .Clear .Select acSelectionSetAll, , , gpCode, dataValue GetColoredEntities = .Count > 0 End With End Function Quote
BIGAL Posted August 30, 2017 Posted August 30, 2017 there are a lot of element in diffrent colors and all are in layer 0 I would do like above posters make a little sub to check colour layer actually exists, then only difference is I would just make the layer name the colour number and then at end change the layer names to something meaningfull. This way just keep going until end of drawing, if you have rgb colours then layer could be R-G-B 123-100-200 Quote
RICVBA Posted August 30, 2017 Posted August 30, 2017 With ThisDrawing.Layers.Add ("Red") It adds the wanted layer if not already there or it does nothing (not even throws any error) if it exists already Quote
