Cgoff Posted April 26, 2017 Posted April 26, 2017 I work for a utility company and we developed a system to export data from a database that contains information (UTM locations and identifier tag numbers) about utility poles on our system, then we converted that data into a .csv file and used a LISP file to import that data into AutoCAD where it would place a block in the correct position on a landbase map according to its UTM coordinates. We first started using this LISP file on AutoCAD Map 3D 2007 (also worked with standard AutoCAD 2007 as well) and continued to use it successfully for all versions up until 2017. When we recently updated our version to ACAD Map 3D 2017, I tried to run this LISP routine and I would immediately get an error and it would promptly abort the command. We tried this file on a few other computers in the office and got the same results. I was fortunate that I still had a version of 2014 on my PC so we could continue to move work along, but in the meantime we are losing productivity in processing these jobs and we are not proficient in LISP coding to troubleshoot the problem. I don't know if we are alone in having LISP files malfunction with the 2017 version of AutoCAD, but if anyone can give me some guidance on what may be causing the issue, I'd greatly appreciate it! I have attached the file below, so take a look and see if there is any way to make this work again! Thanks! insblk2.lspFetching info... Quote
Murph_map Posted May 9, 2017 Posted May 9, 2017 Can you provide a small sample of the CVS file you are using with this? Also the dcl file (insblk2.dcl) . Quote
SLW210 Posted May 10, 2017 Posted May 10, 2017 I moved your thread to the AutoLISP, Visual LISP & DCL Forum. Quote
Cgoff Posted May 10, 2017 Author Posted May 10, 2017 Thank you! I'll get those .cvs and .dcl files added as well! Quote
Cgoff Posted May 10, 2017 Author Posted May 10, 2017 insblk2.dclFetching info... Here are the .dcl and .csv files that we use. In the .csv, the columns are as follows: A) Block reference (selects which block in the template file to place at the locations provided... you can alter this to choose a block you currently have in your library) B) Easting (UTM Meters) C) Northing (UTM Meters) D) Null field E) Note to attach to attribute in the block- ID number F) Note to attach to attribute in the block- Easting G) Note to attach to attribute in the block- Northing If you need anything else, let me know and I'll try to get it posted. AutoCAD Output.csvFetching info... Quote
BIGAL Posted May 11, 2017 Posted May 11, 2017 If you want the simplest answer then use this http://www.lee-mac.com/ptmanager.html Not sure why you need the dcl code if your just after a simple read a csv and make blocks. Even easier open in excel and use this line in column I =CONCATENATE("-insert ",A1," ",B1,",",C1," 1 1 0 ",E1,CHAR(13),F1,CHAR(13),G1,CHAR(13)) just copy down then copy and paste to notepad use replace to remove " save as a SCR file then type script and choose the file your blocks should appear. Quote
Cgoff Posted May 19, 2017 Author Posted May 19, 2017 Thanks BIGAL! I'll give that a try and see if it fixes the issue. Quote
