Before Posting
Browse the help file, hit F1 while in Autocad.
Run through the 'Learning Assistance' CD tutorials.
1) I can't draw accurately ?
Use OSNAPS, found in the TOOLS>Drafting Settings menu
or 'type and shoot', click somewhere then using ORTHO
type in a size.
2) Why do I only have a few linetypes available ?
You need to load more linetypes using the LAYER manager.
3) I can't plot to the right scale ?
You need to setup a LAYOUT with the correct scaled viewport
and plot settings
4) I see all my linetypes as continous on screen. whats wrong?
Adjust linetypescale (default value is 1.000). By hitting Ctrl+1
and seeing the properties docker popping up.
5) I have assigned colour to newly created layer. but all
objects made in that layer show different colur?
check..if the current colour is not "bylayer", your object will not
have same colour as you assigned to its layer. select "bylayer"
option from colour manager box from properties toolbar.
6) I can't get the right scale in Paperspace.
Instead of using zoom 1/(whatever) try using 1/(whatever)XP, it scales in paperspace.
Please post up any other items to add.
Draft 10/03/05
  • 9 months later...
i see all my linetypes as continuos on screen. whats wrong?
adjust linetypescale (default value is 1.000).
i have assigned colout to newly created layer. but all objects made in that layer show different colur
check..if the current colour is not "bylayer", your object will not have same colour as you assigned to its layer. select "bylayer" option from colour manager box from properties toolbar.
  Quote
LESS IS MORE!! More is "NO MORE".
  • 1 month later...
  • 6 months later...
You could also load linetypes w/ LINETYPE command.
  • 2 months later...
also, open the "viewports" menu tab(right click on any icon and select viewports) then at the menu tab just type in ur desire desired scale and presto..... but u have to be in model space before typing ur scale.... :D
  • 3 months later...
If you highlight the viewport you can change the scale in paperspace.
I do it all day everyday.
  • 3 months later...
thanks Mr T for the good idea. helps newbies like moi :)
  • 3 months later...
This FAQ would be good as a wiki type thread ?????
Nick
  • 3 months later...
Wow 10,000 views.
Nick
  • 1 year later...
Select the view port in paperspace and in properties change the "custom scale" to whatever you want it to be.
KennyJ,
The post you are replying to is rather an old one! :wink:
Welcome to the forum though :)
  • 7 months later...
  Quote
I have had this problem before, and note that 3D polylines will not generate a linetype, and also in the properties docker there is a drop down for linetype generation. When it says no, your linetypes are not shown. When it says yes, they are.
I think the optimum answer to loading often used linetypes as well as often used layers is to make a template file (one for metric & one for imperial) with several layers & the most common linetypes already loaded. That way when you create a new drawing, you can just load template,dwg & start drawing.
Layers:
Object
Center
Dimension
Construction
Title_Block
Hidden
Linetypes:
Center
Hidden
Continuous (Pre-loaded)
Or any other linetypes you use in the majority of your drawings.
  • 2 weeks later...
how do i plot multiple dwgs or layouts at once.
either publish or use sheet set manager, make sure you have page setups created with correct plotters first!
This topic is now closed to further replies.
