I need a simple Lisp,
Drawing File i have attached
In put we can provide A,B,F,G values .
“B” value will vary each drawing. According that I need draw this line diagram
:D
TEST.dwg
If you are looking for a LISP, you would be better off posting in the LISP forum but I think a dynamic block would work for this.
Yes, you said that.
There are other ways of doing it.
Have you tried looking in the LISP forum?
Your sample doesn't quite match the problem
Assuming the angle shown are the basis for the shape :
If G is to be constant, F's true value will be constant. F's delta on the X axis will change
Point E will rotate around point A as well as C & D
It his what you are looking for ?
Big hint look for "Draw pipe at grade" or "Draw line at grade" I am sure it exists.
% is easy, height diff = length*%/100.0 every day as a civil engineer.
Also the 0.5 dia is not a vertical measurement but rather a parallel to grade line. The 135 angle can then be worked out based on the line angle +- etc
Its a lisp that would be good for a beginer to tackle I take it by the number of posts Vijoy your starting out. So some help but not code, the bold is the lisp just have a look at some sample code here.
Pick start point Getpoint
enter L & % & Dia
use polar to work out new end point from start point.
get angle of new line
use polar twice to work out 135 deg end point
use a pline pline pt1 pt2 pt3 pt4 C
as you have thes points you can now label and dimension 2nd step next lesson.
Save this file, then you can use "appload" or drag and drop it onto Autocad. Then just copy the next line to the command line and hey you have a front end all done.
(ah:getval3 "Enter Length" 5 4 "Enter % " 5 4 "Enter dia" 5 4)
GETVALS.lsp
Edited by BIGAL
