Hello,
I'm using Lee Mac cad lisp program "PolyInfo V 1.3." for exporting polylines vertex coordinates. But for full work joy I need some modifications.
URL for program: http://www.lee-mac.com/polyinfo.html
URL for code: http://www.lee-mac.com/lisp/html/PolyInfoV1-3.html
As you saw the program exports a lot of information about the polyline. So i want to modify the code that will export just polyline start vertex points x and y coords in two columns ( my cad version information exports to txt file ).
The result should look like this:
________________________________
Polyline starts points x
649542.45
649542.35
649542.28
Polyline starts points y
495232.54
495232.23
495232.41
Can someone help to figure out which part of code I must to modify to get the result i want? Please.
Unfortunately I did, but I'm using not exact AutoCAD program. I'm using ZW CAD. I's cheaper version of cad program. So the comand line promt " ** Dialog File could not be Written ** ". Yach sometimes not all lisp programs works.
I just found an easier code of exporting X Y coordinates.
URL : http://www.eng-tips.com/viewthread.cfm?qid=195727
It is almost what i need. The result of code : (x coordinate) , (Y coordinate)
But, can I change the code that coords print not in line, but in separated columns? for example:
(x coordinate)
(x coordinate)
(Y coordinate)
(Y coordinate)
You can go back to 1st step basics and use the 'getcoordinates function then export what you want in the way you want. have a look at this example.
; pline co-ords example
; By Alan H
(defun getcoords (ent)
 (vlax-safearray->list
   (vlax-variant-value
     (vlax-get-property
   (vlax-ename->vla-object ent)
   "Coordinates"
(defun co-ords2xy ()
; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
(setq len (length co-ords))
(setq numb (/ len 2)) ; even and odd check required
(setq I 0)
(repeat numb
(setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
(setq co-ordsxy (cons xy co-ordsxy))
(setq I (+ I 2))
; program starts here
(setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
(co-ords2xy) ; list of 2d points making pline
(princ co-ordsxy)
  • 7 months later...
want change this
Labeling N,E Coordinates with Leader - David B. Stewart
(defun C:LP(/ PNT1 P1X P1Y STDY DY COORDN COORDE PTXT)
(setq PNT1 (getpoint
"\nPick coordinate point: "))
(setq P1X (car pnt1)) ;x coord
(setq P1Y (cadr pnt1)) ;y coord
(setq STDX (rtos P1X 2 2))
(setq STDY (rtos P1Y 2 2))
(setq COORDN (strcat "N=" STDY ))
(setq COORDE (strcat "E= " STDX ))
(setq PTXT (getpoint
"\nPick text location: "))
(command "LEADER" PNT1 PTXT "" COORDN COORDE "")
come this way
N=8566159.79
E= 505422.47
wanted this way
N=8.566.159,79
E= 505.422,47
Want to know if it is possible that default
Edited by leo321
wanted this way
N=8.566.159,79
E= 505.422,47
never seen such number format, comma as decimal point?
not this?
N=8,566,159.79
E= 505,422.47
google "format number with thousand separator" many examples with others language as well
