Script file to write entire set of drawings to a a new folder using WBLOCK
Hi, I have this batch file that opens each drawing in a specific folder, does a purge on each file, then saves and closes it.
What I'd like to do is add a WBLOCK command to that script file that would write the entire drawing to a designated folder, but instead of calling the new file 'new block.dwg' (which is the default name), it would use the same name as the original.
Below are a few lines from the script file and I'd like to insert the WBLOCK command after the purges.
Is that possible?
Many thanks
_open "U:\Project\A - CURRENT DRAWINGS\TitleBlock.dwg"
_purge all * no
_purge all * no
_purge all * no
_zoom extents
_qsave
_close
  • Replies 20
  • conradsteve
    10
  • ReMark
    5
  • Steven P
    2
  • nukecad
    1
Is there a way to invoke the WBlock command that does not result in a dialog box?
Instead of wblock'ing the whole drawing could you not do a _-saveas to the designated folder straight after the _qsave?
Using the hyphen would keep it on the command line without opening a dialogue.
Thanks, but the WBLOCK gets rid of a lot of garbage that's in drawings and leaves you with a cleaner, leaner, smaller, faster-opening drawing.
For cleaning drawings I'd recommend the following...
Overkill
-Purge (Regapps first)
-Purge (ALL)
Audit and respond "yes" to fixing all errors that are found.
I can't see a way to add WBlock to a script. Maybe you "call" a lisp routine to handle this command?
Thanks ReMark. I'll try looking for a lisp routing that I can invoke from the script file.
I tried overkill on a couple of the files and the wblock seemed to have better results for me.
With 360 more files to clean up, the lisp routine within the script file is the way to go for me
Thanks again.
WBlock and Overkill have two different purposes. One is not a substitute for the other.
Of course, you're correct. I misspoke. My intent was not to get rid of duplicate lines, but to cleanup hidden garbage that seems to bloat up drawings. For that, WBLOCK is my best friend
And you would be surprised to see how many duplicate or overlapping objects will be found using Overkill.
I'm sort of scared to use it as we often have lines on top of each other, but in different layers.
Or we had 2 polylines on the same layer and one polyline was drawn thin and one thick and the thick one should be kept.
I'll read up on the command before I use on a real drawing
You should be able to use the -WBLOCK command in a script.
Which also means one should be able to invoke the -WBLOCK command at the command line right?
I got it to work by adding the following line to my script
-WBLOCK "c:/X/TEMP.DWG" "*"
I have to get the filename of the new drawing to be the same as each drawing that i open (all 362 drawings), but I'm working on that
would something like this help?
(vl-filename-base (getvar 'dwgname))
You might need to use
(vl-load-com)
at the start of your script too
Thanks to all who are trying to help me.
Here's the code that I'm working with.
It pops up a dialg box asking to select a drawing from a folder and then creates a batch file that performs commands on all the drawings in that folder
I did not write the program (no surprise there, as it's obvious to all that I don't know my arse from my elbow when it comes to programming), but I did add the WBLOCK line
However, Autocad is not happy as it says that I've too many arguments.
Is is obvious to anybody where I went wrong?
(defun C:RV ( / COUNT DIR FILENAME FILES SCRIPTNAME)
(if (setq dir (getfiled "Select the drawing directory:" "" "dwg" 0))
(setq dir (vl-filename-directory dir))
(if dir
(setq files (vl-directory-files dir "*.dwg" 1))
(if files
(setq scriptname (open "C:\x\batch.scr" "w")
count 0
(while (setq filename (nth count files))
(setq filename (strcat dir "\\" filename))
(write-line (strcat "_open \"" filename "\"") scriptname)
(write-line "_purge all * no" scriptname)
(write-line "_FILEDIA 0" scriptname)
(write-line -WBLOCK (strcat "c:/X/" (getvar 'dwgname) "*") scriptname)
(write-line "_FILEDIA 1" scriptname)
(write-line "_zoom extents" scriptname)
(write-line "_qsave" scriptname)
(write-line "_close" scriptname)
(setq count (1+ count))
(close scriptname)
Edited by SLW210
Added Code Tags
(if dir
(if files
count 0
(close scriptname)
