blintz Posted April 3, 2017 Posted April 3, 2017 Hello with vba / autocad I make a form for extract, from block, the attributes. This block contains 37 different attributes. A combobox reads the blocks present in model space, select the block in textbox read value attribute e.g. attrib. "1Tag" = "01" value attrib. "2Tag" = "02" value etc .. I want to insert new value of attribute in the block e.g old TextBox2 / attrib. "1Tag" = "01" value new TextBox2 / attrib. "1Tag" = "AA" value code: Private Sub ComboBox1_Change() '<<<<<<<------------- Dim BlockRef As AcadBlockReference Dim varAttributes As Variant Dim intAttribCount As Integer Dim newss As AcadSelectionSet Dim i, o, x As Integer ' Cancella la Selection Set se esiste On Error Resume Next If Not IsNull(ThisDrawing.SelectionSets.Item("ss")) Then Set newss = ThisDrawing.SelectionSets.Item("ss") newss.Delete End If ListBox1.Clear TextBox32.Value = 0 TextBox1.Value = ComboBox1.Value Set newss = ThisDrawing.SelectionSets.Add("ss") newss.Select acSelectionSetAll If newss.Count > 0 Then i = 1 o = 0 For x = 0 To newss.Count - 1 newss.Item (o) If newss.Item(o).ObjectName = "AcDbBlockReference" Then If newss.Item(o).EffectiveName = TextBox1.Value Then i = i + 1 varAttributes = newss.Item(o).GetAttributes For intAttribCount = LBound(varAttributes) To UBound(varAttributes) If varAttributes(intAttribCount).TagString = "1REV" Then TextBox2.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "2REV" Then TextBox3.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "3REV" Then TextBox4.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "4REV" Then TextBox5.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "1MOD_REV" Then TextBox6.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "2MOD_REV" Then TextBox7.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "3MOD_REV" Then TextBox8.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "4MOD_REV" Then TextBox9.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "1DATA_REV" Then TextBox10.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "2DATA_REV" Then TextBox11.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "3DATA_REV" Then TextBox12.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "4DATA_REV" Then TextBox13.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "1FIRMA_REV" Then TextBox14.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "2FIRMA_REV" Then TextBox15.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "3FIRMA_REV" Then TextBox16.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "4FIRMA_REV" Then TextBox17.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "DATA_CREAZIONE" Then TextBox18.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "DISEGNATORE" Then TextBox19.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "VISTO" Then TextBox20.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "APPROVATO" Then TextBox21.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "LINK" Then TextBox22.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "1CLIENTE" Then TextBox23.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "2CLIENTE" Then TextBox24.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "MOD_MACCHINA" Then TextBox26.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "1MATR" Then TextBox27.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "2MATR" Then TextBox28.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "#N-1" Then TextBox29.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "#N" Then TextBox30.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "#N+1" Then TextBox31.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "1SE_POT" Then TextBox33.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "2SE_AUX" Then TextBox34.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "3SE_PLCIN" Then TextBox35.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "4SE_PLCOUT" Then TextBox36.Value = varAttributes(intAttribCount).TextString ElseIf varAttributes(intAttribCount).TagString = "5SE_PLCLAYOUT" Then TextBox37.Value = varAttributes(intAttribCount).TextString '"ETC. ETC." End If If TextBox33.Value = "" Then Else TextBox25.Value = TextBox33.Value End If If TextBox34.Value = "" Then Else TextBox25.Value = TextBox34.Value End If If TextBox35.Value = "" Then Else TextBox25.Value = TextBox35.Value End If If TextBox36.Value = "" Then Else TextBox25.Value = TextBox36.Value End If If TextBox37.Value = "" Then Else TextBox25.Value = TextBox37.Value End If Next intAttribCount ListBox1.AddItem (o) o = o + 1 ElseIf newss.Item(o).EffectiveName <> TextBox1.Value Then o = o + 1 End If ElseIf newss.Item(o).ObjectName <> "AcDbBlockReference" Then o = o + 1 End If Next x End If TextBox32.Value = i - 1 End Sub With the "EXIT" button close the form but strangely vba editor does not end the macro code Private Sub CommandButton3_Click() Unload Me Set UserForm1 = Nothing End Sub I hope for your help regards Quote
