toxicsquall Posted March 30, 2017 Posted March 30, 2017 Hello, I have this Lisp MD (Closest Distance Between Two Objects).lsp that can show me what is the shortest distance between two objects. If you type MD it shows the distance value and if you type MDL, it draws a line between them on the closest point distance. It can be useful for you if you need. But I need the right opposite of it. I need the Longest Distance between two objects. I need the number and the line of it. Can someone help me? Quote
BIGAL Posted March 31, 2017 Posted March 31, 2017 There are a number of places where something like this is checking (> dist x) for longest ( Quote
marko_ribar Posted March 31, 2017 Posted March 31, 2017 But I need the right opposite of it. If you are searching for longest distance between 2 curves like in your posted lisp, you have many ways to get those 2 points... There is my sub function posted here : https://www.theswamp.org/index.php?topic=42246.msg507763#msg507763 , which you can use to get furthest point from checking point... Another way and I think is better is to segment reference curves and then supply point list to Lee Mac's MinEnclosingCircle sub function, after which instead of drawing minimum enclosing circle, you can check 2 or 3 touching points for longest distance - that 2 points that satisfy relation of longest distance would be solution to your task... You can finally draw line or use that data for your needs as you wish... MinEnclosingCircle - look here : http://www.lee-mac.com/minimumenclosingcircle.html HTH., M.R. Quote
Grrr Posted April 1, 2017 Posted April 1, 2017 If you are searching for longest distance between 2 curves like in your posted lisp, you have many ways to get those 2 points... There is my sub function posted here : https://www.theswamp.org/index.php?topic=42246.msg507763#msg507763 , which you can use to get furthest point from checking point... Sounds awesome, Thanks for sharing it, Marko! Quote
