aawilds Posted March 28, 2017 Share Posted March 28, 2017 I am looking for a lisp that will allow me to convert survey figures to flat polylines. Currently I have to select them explode which makes 3dpolylines then convert to 2dpolylines. I then use the flatten command. I have tried making a lisp that uses (command "_explode") and (command "_flatten") and am having trouble getting them to work. Does anyone have any suggestions? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted March 28, 2017 Share Posted March 28, 2017 IIRC, you can't pass arguments to the flatten command because it is defined with lisp itself. The C3D command "3D to 2D polylines" works, sort of, but it doesn't move the items to 0.0 elevation. Here is something with which to start. No error checking obviously. (defun c:foo () (setq ent (car (entsel "\nSelect Figure"))) (vl-cmdf "explode" ent) (vl-cmdf "CONVERT3DPOLYS" "_L" "") ) I suppose you could end the routine with (c:flatten) and then finish it off manually. You could also set the explode to loop through a selection set, and then flatten the entire selection set. Lot of ways to tackle this. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 29, 2017 Share Posted March 29, 2017 Another way is to retrieve the 3d components and make a new pline erase old one. This is not tested ; pline co-ords example ; By Alan H (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun co-ords2xy () ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (setq len (length co-ords)) (setq numb (/ len 2)) ; even and odd check required if frac is 0.5 then its odd has Z (setq I 0) (repeat numb (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ; program starts here (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) ; list of 2d points making pline (command "_pline") (repeat (setq x (length co-ordsxy)) (setq xy (nth (setq x (- x1)) co-ordsxy)) (command (list (nth 0 co-ordsxy)(nth 1 co-ordsxy))) ) Quote Link to comment Share on other sites More sharing options...
ccowgill Posted March 29, 2017 Share Posted March 29, 2017 The downside to exploding to 3d polylines is you don't get any curved segments. our procedure isn't create a rectangle, make it a break line in a temporary surface. set the elevations of the survey figures to match the temp surface (0), explode the feature lines, this makes them 2d. erase the surface and the rectangle. I'm not sure this can be done with lisp as it requires a little too much interaction. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 29, 2017 Share Posted March 29, 2017 Look at Lee-mac website and he has a great pline routine including bulge info. One of the things with a bulge is that in 3d its a planar answer sometimes in the plane of the before and after lines, so the radius can be something different when converted to 2d. Bit hard to explain. Forcing the bulge points to be z=0.0 can make just that a bulge. Also CIV3D does not support arcs as breaklines interesting our 20 year old software asks how many facets you want for arcs in break lines, often CIV3D is so far behind. Quote Link to comment Share on other sites More sharing options...
tombu Posted March 29, 2017 Share Posted March 29, 2017 I am looking for a lisp that will allow me to convert survey figures to flat polylines. Currently I have to select them explode which makes 3dpolylines then convert to 2dpolylines. I then use the flatten command. I have tried making a lisp that uses (command "_explode") and (command "_flatten") and am having trouble getting them to work. Does anyone have any suggestions? Congratulations on your first post! What type of survey figures and what are you looking to do with them? There's usually several solutions to every problem with AutoCAD. Are these figures extractable? Quote Link to comment Share on other sites More sharing options...
aawilds Posted March 29, 2017 Author Share Posted March 29, 2017 This is great, I did not know that flatten was it's own lisp. Being able to reduce the button clicks is a lifesaver. This helps a lot thank you. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted March 29, 2017 Share Posted March 29, 2017 What type of survey figures and what are you looking to do with them? I think OP answered that in the initial post. ...convert survey figures to flat polylines... Quote Link to comment Share on other sites More sharing options...
tombu Posted March 29, 2017 Share Posted March 29, 2017 I think OP answered that in the initial post. Figures are editable and as this was a newbie poster they could be fairly new to Civil. There could be a really simple solution to what they're wanting to accomplish. aawilds what type of survey figures and what are you going to use the polylines for? Quote Link to comment Share on other sites More sharing options...
