reynaldomalasaga Posted March 24, 2017 Posted March 24, 2017 Good Day sir/maam.. Can someone help me!!!!! is thier lisp program that will create text that displays the x,y coordinates for a selected object? thank you !!! sir Quote
BIGAL Posted March 24, 2017 Posted March 24, 2017 Plenty of them here just search for "label points" various options, plain text, stacked x/y, leader style etc. Quote
tombu Posted March 24, 2017 Posted March 24, 2017 Old one to get you started, you'll need to place Pt_Coordinates.dwg attached into a support directory along with the code. ;| Label for Point. PtLabel.lsp BY: TOM BEAUFORD ^P(or C:Label (load "PtLabel.lsp"));PtLabel BeaufordT@LeonCountyFL.gov Leon County Public Works/Engineering ==================================================================|; (defun C:PtLabel (/ ATTDIA) (setq ATTDIA (getvar "ATTDIA")) (setvar "ATTDIA" 0) (command "._INSERT" "Pt_Coordinates" (getpoint "Pick Point: ") ;Insert pt (/ 0.1 (getvar "cannoscalevalue")) ;X Scale ; (* (getvar "DIMTXT") (getvar "DIMSCALE")) ;X Scale (Alternate) "" ;Y Scale ; "" ;Rotation (*(/(getvar "viewtwist")pi)-180) ;Rotation "" ;Easting "" ;Northing ) (setvar "ATTDIA" ATTDIA) (entupd (entlast)) ; (command "._DDATTE" (entlast)) (princ) ) Pt_Coordinates.dwg Quote
StevJ Posted March 24, 2017 Posted March 24, 2017 Here's a simple one that shows the coordinates in the command line. (defun c:XY (/ p x y) (while (setq p (getpoint "\nPick Point: ")) (princ (strcat " X = " (rtos (car p)) " Y = " (rtos (cadr p)) ) ) ) ) Steve Quote
reynaldomalasaga Posted March 28, 2017 Author Posted March 28, 2017 thank you masters:shock::shock: thank you so much!!! Quote
