Hello im new to autocad with civil 3d 2017 being my first, i have to files dwg(survey's plan) and a pdf of a structure l wanna place on the on the land, ive already imported both files in civil. My question is it possible to overlay and get a render? drawing1 kingshill.pdf
you can attach DWGs and PDFs using command XR then changing the drop-down in the top left from DWG to PDF. or command XATTACH or PDFATTACH does the same. Sorry, I don't know about rendering, but someone here will.
Doesn't rendering imply the application of materials to 3D models? This is a 2D drawing is it not?
