jim78b Posted March 23, 2017 Author Posted March 23, 2017 block notes a text editor . ok but don't work Quote
ReMark Posted March 23, 2017 Posted March 23, 2017 YES! It does work. I tested it....twice. Did you use the APPLOAD command to load the lisp routine? Yes or No? Did you execute the polylinewidthzero command to run the lisp routine? Yes or No? Did you independently test the routine in a new drawing like I did? Yes or No? Quote
jim78b Posted March 23, 2017 Author Posted March 23, 2017 yes to all three questions no i try again Quote
jim78b Posted March 23, 2017 Author Posted March 23, 2017 ok work PIB!!! but only thing, i have a nested blocks...and only work for first block on top..... polywidthzero work !!!! thanks but Am I asking too much if the pib.lsp can working with nested blocks? Quote
jim78b Posted March 23, 2017 Author Posted March 23, 2017 I can't answer that question. Sorry However the global lisp work very Well !!!You are very kindly. Thanks very much. I open a dwg in me10 and i understand the problem is me10 !!!I resave the dwg and when open it me10 put some lines with various width . Quote
jim78b Posted March 23, 2017 Author Posted March 23, 2017 I am surprise what i found !!!!My Friend has autocad mech 2011 and if i draw a pline with width 0.1 or 0.01 and move it i don't views the preview !is it a autocad bug? Quote
ReMark Posted March 23, 2017 Posted March 23, 2017 I doubt it. I think it is OIE (Operator Induced Error) meaning it is self-inflicted. Quote
jim78b Posted March 23, 2017 Author Posted March 23, 2017 I doubt it. I think it is OIE (Operator Induced Error) meaning it is self-inflicted. Mmm sure ?but if i set width 0.1 autocad must show me The preview when drag item. .. Quote
ReMark Posted March 23, 2017 Posted March 23, 2017 You're working in millimeters aren't you? Why not just say it is "0" and be done with it? When you print the drawing, full size, is a polyline with a width of 0.1 going to appear any different than one with a width of 0? Quote
jim78b Posted March 23, 2017 Author Posted March 23, 2017 You're working in millimeters aren't you? Why not just say it is "0" and be done with it? When you print the drawing, full size, is a polyline with a width of 0.1 going to appear any different than one with a width of 0? YES IN MM. BUT THE PROBLEM IS not plotting. the problem is working in a dwg where i move , copy blocks and i don't see what i doing. Quote
Cad64 Posted March 23, 2017 Posted March 23, 2017 We know the problem is polyline widths that are less than 0, so my advice would be for you to start a new thread in the lisp section here: http://www.cadtutor.net/forum/forumdisplay.php?21-AutoLISP-Visual-LISP-amp-DCL, post that lisp routine and ask for someone to modify it to work on nested blocks. And make sure you mention that the code came from Lee Mac. It's not polite to post code without giving credit to the author. Quote
jim78b Posted March 23, 2017 Author Posted March 23, 2017 We know the problem is polyline widths that are less than 0, so my advice would be for you to start a new thread in the lisp section here: http://www.cadtutor.net/forum/forumdisplay.php?21-AutoLISP-Visual-LISP-amp-DCL, post that lisp routine and ask for someone to modify it to work on nested blocks. And make sure you mention that the code came from Lee Mac. It's not polite to post code without giving credit to the author. Oh sure thanks you are very kind and useful!!! thanks a lot!! Quote
