tsotzo Posted March 20, 2017 Posted March 20, 2017 Hello, Let's say we have a group of integers as text in dwg. How would we put them in in ascending order by one(+1) starting from a given integer? Let me give an example to make it clear. Let's say we have the texts 1 2 5 5 5 8 9 11 11 15 and the given start integer is 6. We select them all together and the range in selection set is random. Let's say 5 2 8 15 1 5 5 11 9 11. Now, we want to put them in ascending order by one starting from number 6 replacing the "old" range with the new. In the end we must have this: 6 7 8 8 8 9 10 11 11 12. That is 6(in place of 1), 7(in place of 2), 8(5), 8(5), 8(5), 9(, 10(9), 11(11), 11(11), 12(15). I hope it is clear. How would we do that in an efficient way? Thank you in advance, Kostas Quote
Lee Mac Posted March 20, 2017 Posted March 20, 2017 Consider the following code: (defun renumberlist ( num lst ) (setq lst (vl-sort lst '(lambda ( a b ) (< (atoi a) (atoi b)))) num (1- num) ) (mapcar '(lambda ( a b ) (if (= a b) (itoa num) (itoa (setq num (1+ num))))) (cons nil lst) lst) ) Example: _$ (renumberlist 6 '("5" "2" "8" "15" "1" "5" "5" "11" "9" "11")) ("6" "7" "8" "8" "8" "9" "10" "11" "11" "12") Quote
Grrr Posted March 20, 2017 Posted March 20, 2017 Consider the following code: Its impressive how fast you understand peoples tasks/problems. Quote
tsotzo Posted March 20, 2017 Author Posted March 20, 2017 Thank you Lee Mac! I will try to import your code to my routine. If I don't manage, I will come back to you. (It's very possible because your coding is in much higher level than mine). Thanks! Quote
Lee Mac Posted March 20, 2017 Posted March 20, 2017 Its impressive how fast you understand peoples tasks/problems. Thanks Thank you Lee Mac! I will try to import your code to my routine. If I don't manage, I will come back to you. (It's very possible because your coding is in much higher level than mine). Thanks! You're welcome tsotzo. My code demonstrates one possible method of ordering & renumbering a set of text values, however, assuming you are looking to then modify the text content, you will need to retain the entity name of the text object during the sorting & renumbering process - I'm happy to demonstrate this if you get stuck. Quote
Lee Mac Posted March 20, 2017 Posted March 20, 2017 Just for fun, here's a recursive function accepting a sorted list to produce the same result: (defun renum ( num lst ) (if lst (cons (itoa num) (renum (if (= (car lst) (cadr lst)) num (1+ num)) (cdr lst)))) ) Example: _$ (renum 6 (vl-sort '("5" "2" "8" "15" "1" "5" "5" "11" "9" "11") '(lambda ( a b ) (< (atoi a) (atoi b))))) ("6" "7" "8" "8" "8" "9" "10" "11" "11" "12") Quote
Lee Mac Posted March 20, 2017 Posted March 20, 2017 OK, I couldn't resist ([color=BLUE]defun[/color] c:renum ( [color=BLUE]/[/color] a b i l n s x y z ) ([color=BLUE]initget[/color] 4) ([color=BLUE]setq[/color] n ([color=BLUE]1-[/color] ([color=BLUE]cond[/color] (([color=BLUE]getint[/color] [color=MAROON]"\nSpecify starting number <1>: "[/color])) (1)))) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"TEXT"[/color]) (1 . [color=MAROON]"~*[~0-9]*"[/color])))) ([color=BLUE]progn[/color] ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s)) ([color=BLUE]setq[/color] x ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i)))) a ([color=BLUE]cons[/color] ([color=BLUE]assoc[/color] -1 x) a) b ([color=BLUE]cons[/color] ([color=BLUE]atoi[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 1 x))) b) ) ) ([color=BLUE]setq[/color] i ([color=BLUE]vl-sort-i[/color] b '[color=BLUE]<[/color]) l ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( n ) ([color=BLUE]nth[/color] n b)) i) ) ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( x y z ) ([color=BLUE]entmod[/color] ([color=BLUE]list[/color] ([color=BLUE]nth[/color] z a) ([color=BLUE]cons[/color] 1 ([color=BLUE]itoa[/color] ([color=BLUE]if[/color] ([color=BLUE]=[/color] x y) n ([color=BLUE]setq[/color] n ([color=BLUE]1+[/color] n)))))))) ([color=BLUE]cons[/color] [color=BLUE]nil[/color] l) l i) ) ) ([color=BLUE]princ[/color]) ) Quote
tsotzo Posted March 20, 2017 Author Posted March 20, 2017 & & . Lee Mac, when I first read your message I laughed with my heart and then... wow... I have no words...! You are unbelievable! You know, I had written more than double of code lines than you, and I wasn't even in the middle! What can I say... Thanks man!! You know, what's impressive is not only that you solve the problem, but the way that you do it (and the speed of course ). Thanks again! Quote
Lee Mac Posted March 20, 2017 Posted March 20, 2017 & & . Lee Mac, when I first read your message I laughed with my heart and then... wow... I have no words...! You are unbelievable! You know, I had written more than double of code lines than you, and I wasn't even in the middle! What can I say... Thanks man!! You know, what's impressive is not only that you solve the problem, but the way that you do it (and the speed of course ). Thanks again! Thank you for your kind words & compliments, you're most welcome. This was an enjoyable program to write, and so after pointing you in the right direction, I couldn't resist coding a solution I welcome you to continue with your attempt - there is often more than one way to solve the problem, and nothing is more valuable in programming than practice! Quote
