Opening revit file
Hi Everyone,
I am a new Revit user and when I try to open a file, this message pop-up on my screen, can anyone please tell me what is the problem?
Thanks in advance!
I'm assuming you are double-clicking the Revit model. This is typically seen as a huge no-no. You must always go through the Open dialog box because Revit models are usually always a Workshared file, therefore the files you receive will be a Central Model. The Open dialog has steps to open these files correctly, in which you would be bypassing when you simply double-click the file in Windows Explorer.
You will have to become familiar with Worksharing, Central Models, and Local Copies:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-Collaborate/files/GUID-3896288A-0729-4C41-A67D-4FA970DF3E43-htm.html
and
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/files/GUID-71B6BE0F-019B-45B3-B88C-F1ABBAFA66AE-htm.html
-TZ
Hi TZ,
Thank you it helps me lot... :D :D
More power!
