catphe10 Posted March 8, 2017 Posted March 8, 2017 Hello, I have a drawing with approximately 4400 points in it. and a file folder with the same number of files. What i am looking for is a lisp routine that will use the point description and then create a hyperlink to the file in the folder with the name that is the same as the description. So if i have a point thats description is 43804152000, the lisp routine would go to the folder where all the hyperlink files are saved and hyperlink to the file named 43804152000. I have zero knowledge in lisp routines and would appreciate any help! Thanks, Quote
Roy_043 Posted March 8, 2017 Posted March 8, 2017 Since 'normal' points do not have a description, are you perhaps referring to Cogo points? Quote
catphe10 Posted March 8, 2017 Author Posted March 8, 2017 Yes, they were brought in from a surveying data collector. Quote
Roy_043 Posted March 9, 2017 Posted March 9, 2017 I am afraid I can't help you then since I use BricsCAD instead of AutoCAD. It may help members who do use AutoCAD but not Civil 3D, if you post a dwg with a couple of those Cogo points. Quote
