Lee Mac Posted March 12, 2017 Posted March 12, 2017 Grrr said: I think you mean here is the solution. ........ Quote
grouch19 Posted March 12, 2017 Author Posted March 12, 2017 Thanks Lee Works perfectly! Thanks BIGAL for all your help too. Appreciate the help guys! Quote
Ajmal Posted July 1, 2021 Posted July 1, 2021 Dear Lee when i run the code its showing ; error: extra cdrs in dotted pair on input (defun c:insblk ( / blk cmd dwg ent enx idx lst scl sel ) (setq blk "Manhole") ;; Block Name (cond ( (not (or (tblsearch "block" blk) (and (setq dwg (findfile (strcat blk ".dwg"))) (progn (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (command "_.-insert" dwg nil) (setvar 'cmdecho cmd) (tblsearch "block" blk) ) ) ) ) (princ (strcat "\nBlock \"" blk "\" not found or could not be defined.")) ) ( (setq sel (ssget "_:L" '((0 . "POLYLINE") (-4. "&=")(70 . (-4 . "<NOT")(-4 . "&=")(70 . 1)(-4 . "NOT>")))) (repeat (setq idx (sslength sel)) (setq ent (entnext (ssname sel (setq idx (1- idx)))) enx (entget ent) lst nil ) (while (= "VERTEX" (cdr (assoc 0 enx))) (setq lst (cons (cdr (assoc 10 enx)) lst) ent (entnext ent) enx (entget ent) ) ) (if (= 3 (length lst)) (progn (if (apply '< (setq scl (mapcar 'distance lst (cdr lst)))) (setq lst (reverse lst) scl (reverse scl) ) ) (if (minusp (sin (- (angle (car lst) (caddr lst)) (angle (car lst) (cadr lst))))) (setq lst (vl-list* (cadr lst) (car lst) (cddr lst))) ) (if (entmake (list '(000 . "INSERT") (cons 002 blk) (cons 010 (car lst)) (cons 041 (car scl)) (cons 042 (cadr scl)) (cons 050 (angle (car lst) (cadr lst))) ) ) (entdel (ssname sel idx)) ) ) ) ) ) ) (princ) )) Quote
Kvlar Posted June 9, 2024 Posted June 9, 2024 (edited) On 3/11/2017 at 3:35 PM, Lee Mac said: Based on your sample drawing, here is my attempt: ([color=BLUE]defun[/color] c:insblk ( [color=BLUE]/[/color] blk cmd dwg ent enx idx lst scl sel ) ([color=BLUE]setq[/color] blk [color=MAROON]"Manhole"[/color]) [color=GREEN];; Block Name[/color] ([color=BLUE]cond[/color] ( ([color=BLUE]not[/color] ([color=BLUE]or[/color] ([color=BLUE]tblsearch[/color] [color=MAROON]"block"[/color] blk) ([color=BLUE]and[/color] ([color=BLUE]setq[/color] dwg ([color=BLUE]findfile[/color] ([color=BLUE]strcat[/color] blk [color=MAROON]".dwg"[/color]))) ([color=BLUE]progn[/color] ([color=BLUE]setq[/color] cmd ([color=BLUE]getvar[/color] 'cmdecho)) ([color=BLUE]setvar[/color] 'cmdecho 0) ([color=BLUE]command[/color] [color=MAROON]"_.-insert"[/color] dwg [color=BLUE]nil[/color]) ([color=BLUE]setvar[/color] 'cmdecho cmd) ([color=BLUE]tblsearch[/color] [color=MAROON]"block"[/color] blk) ) ) ) ) ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nBlock \""[/color] blk [color=MAROON]"\" not found or could not be defined."[/color])) ) ( ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"POLYLINE"[/color]) (-4 . [color=MAROON]"&="[/color]) (70 . (-4 . [color=MAROON]"<NOT"[/color]) (-4 . [color=MAROON]"&="[/color]) (70 . 1) (-4 . [color=MAROON]"NOT>"[/color])))) ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel)) ([color=BLUE]setq[/color] ent ([color=BLUE]entnext[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx)))) enx ([color=BLUE]entget[/color] ent) lst [color=BLUE]nil[/color] ) ([color=BLUE]while[/color] ([color=BLUE]=[/color] [color=MAROON]"VERTEX"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 enx))) ([color=BLUE]setq[/color] lst ([color=BLUE]cons[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 enx)) lst) ent ([color=BLUE]entnext[/color] ent) enx ([color=BLUE]entget[/color] ent) ) ) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 3 ([color=BLUE]length[/color] lst)) ([color=BLUE]progn[/color] ([color=BLUE]if[/color] ([color=BLUE]apply[/color] '[color=BLUE]<[/color] ([color=BLUE]setq[/color] scl ([color=BLUE]mapcar[/color] '[color=BLUE]distance[/color] lst ([color=BLUE]cdr[/color] lst)))) ([color=BLUE]setq[/color] lst ([color=BLUE]reverse[/color] lst) scl ([color=BLUE]reverse[/color] scl) ) ) ([color=BLUE]if[/color] ([color=BLUE]minusp[/color] ([color=BLUE]sin[/color] ([color=BLUE]-[/color] ([color=BLUE]angle[/color] ([color=BLUE]car[/color] lst) ([color=BLUE]caddr[/color] lst)) ([color=BLUE]angle[/color] ([color=BLUE]car[/color] lst) ([color=BLUE]cadr[/color] lst))))) ([color=BLUE]setq[/color] lst ([color=BLUE]vl-list*[/color] ([color=BLUE]cadr[/color] lst) ([color=BLUE]car[/color] lst) ([color=BLUE]cddr[/color] lst))) ) ([color=BLUE]if[/color] ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(000 . [color=MAROON]"INSERT"[/color]) ([color=BLUE]cons[/color] 002 blk) ([color=BLUE]cons[/color] 010 ([color=BLUE]car[/color] lst)) ([color=BLUE]cons[/color] 041 ([color=BLUE]car[/color] scl)) ([color=BLUE]cons[/color] 042 ([color=BLUE]cadr[/color] scl)) ([color=BLUE]cons[/color] 050 ([color=BLUE]angle[/color] ([color=BLUE]car[/color] lst) ([color=BLUE]cadr[/color] lst))) ) ) ([color=BLUE]entdel[/color] ([color=BLUE]ssname[/color] sel idx)) ) ) ) ) ) ) ([color=BLUE]princ[/color]) ) Demo: Expand when I tried it, I got an error like this: Command: ; error: extra cdrs in dotted pair on input what happened? is there an error when I try it? Edited June 9, 2024 by Kvlar Quote
Lee Mac Posted June 9, 2024 Posted June 9, 2024 The update to the forum software a few years ago unfortunately corrupted many of the code posts; I have now corrected my earlier post. Quote
