katto01 Posted March 1, 2017 Posted March 1, 2017 Hello, Q1. I am not sure how to do this. I have hundreds of lines on a layer that I need to delete. I need to do this in VBA. I do not want to use a selection. just simply delete all lines on a layer. Q2. same question as Q1 but with a condition on color (i.e. if red delete). Thanks Quote
Tyke Posted March 1, 2017 Posted March 1, 2017 Hi Katto01, Here's some sample code to get you going. Delete all lines on layer "Layer1": Sub DelAllOnLayer() Dim oLine As AcadLine Dim oLayer As AcadLayer For Each oLine In ThisDrawing.ModelSpace If oLine.Layer = "Layer1" Then oLine.Delete End If Next ThisDrawing.Regen acActiveViewport End Sub To delete all red lines on layer "Layer1": Sub DelAllOnLayerColour() Dim oLine As AcadLine Dim oLayer As AcadLayer For Each oLine In ThisDrawing.ModelSpace If oLine.Layer = "Layer1" Then If oLine.color = acRed Then oLine.Delete End If End If Next ThisDrawing.Regen acActiveViewport End Sub That should get you going. If you are going to repeat this many times with lots of layers you could have a dialogue box where the layer and colour are entered and using the entered values do the deletions. Ben Quote
katto01 Posted March 1, 2017 Author Posted March 1, 2017 Ben, Thank you for your help In both cases the line "For Each oLine In ThisDrawing.ModelSpace" gives me the error "type mismatch". I am in AutoCAD 2011 Quote
BIGAL Posted March 2, 2017 Posted March 2, 2017 You could try a selection set method Dim SS As AcadSelectionSet Dim FilterDXFCode(0) As Integer Dim FilterDXFVal(0) As Variant FilterDXFCode(0) = 8 FilterDXFVal(0) = "MYLAYER" Set SS = ThisDrawing.SelectionSets.Add("sel1") SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal Quote
Tyke Posted March 2, 2017 Posted March 2, 2017 Ben, Thank you for your help In both cases the line "For Each oLine In ThisDrawing.ModelSpace" gives me the error "type mismatch". I am in AutoCAD 2011 katto01, I can only go back to version 2012 on my computer, but the code works fine there. Instead of copying and pasting the code into your VBA Editor try typing it all in line for line, paying particular attention to what AutoCAD offers when declaring the variable "oLine". You should see this: See if that helps. Ben Quote
katto01 Posted March 2, 2017 Author Posted March 2, 2017 Thanks for the tip. I did what you suggested. That did not change the original code you posted. The problem is still in the "For Each oLine In ThisDrawing.ModelSpace" line. same error Quote
Tyke Posted March 2, 2017 Posted March 2, 2017 Thanks for the tip. I did what you suggested. That did not change the original code you posted. The problem is still in the "For Each oLine In ThisDrawing.ModelSpace" line. same error Are you drawing lines, polylines, or something else? The code will only work with lines, polylines etc will not be deleted. Quote
Tyke Posted March 2, 2017 Posted March 2, 2017 (edited) Try using this declaration for the oLine declaration: Dim oLine As Variant But that will pick all entities on the layer. I tried the code out with just polylines and arcs (no lines) on the layer and got the same error message as you did. Check the properties of the entities on the layer to see that they are lines. Ben Edited March 2, 2017 by Tyke Quote
RICVBA Posted August 29, 2017 Posted August 29, 2017 Use SelectionSet and its powerful filtering and Erase methods Sub DeleteElements() Dim delSset As AcadSelectionSet On Error Resume Next Set delSset = ThisDrawing.SelectionSets.Add("Deletion") On Error GoTo 0 If delSset Is Nothing Then Set delSset = ThisDrawing.SelectionSets.Item("Deletion") Dim gpCode(0 to 2) As Integer Dim dataValue(0 to 2) As Variant gpCode(0) = 0 : dataValue(0) = "LINE" ' filter on line elements only gpCode(1) = 8 : dataValue(1) = "myLayerName" ' filter on given layer gpCode(2) = 62 : dataValue(2) = 1 ' filter on color (1 is the red color dataValue) With delSset .Clear .Select acSelectionSetAll, , , gpCode, dataValue If .Count > 0 Then .Erase End With End Sub Quote
Jings Posted March 20, 2019 Posted March 20, 2019 Simple VBA can delete all objects you need to alter the code to select only lines code can be found here http://www.computeraidedautomation.com/forum-topic/delete-all-objects-autocad-vba Quote
Chad Ehret Posted April 8, 2020 Posted April 8, 2020 (edited) The reason you were getting a "type mismatch" error in the For Each loop is that the collection you're looping through (ThisDrawing.ModelSpace) contains more entity types than just AcadLine objects. You'll need to modify your loop to handle any type of entity, check to see if it's a line, and then delete it if it's a line. Code will probably look something like this: Sub DeleteAllLinesOnLayer(ByVal TargetLayer as String) Dim oEntity as AcadEntity For Each oEntity In ThisDrawing.ModelSpace If oEntity.Layer = TargetLayer And TypeOf oEntity is AcadLine Then oEntity.Delete ThisDrawing.Regen End If Next End Sub Note: The "ThisDrawing.Regen" is there just to force the drawing to be updated so you can see each line being deleted. Of course, all of the other entities on the layer (such as text, arcs, etc.) will be left behind. Edited April 8, 2020 by Chad Ehret Quote
