johan Posted March 1, 2017 Share Posted March 1, 2017 Hello! I have a question like this before but after some answer and help i couldnt make it. I have googled for like 15 hours overall and this is my last way out What i need is to extract data of mutable drawings and change for example the description in the "title block". Not the same description for every drawing, thats why I need it to be in excel. "extract data" is good to get information out. BUT i cant get it into the drawings again... I have tried the LISP "Batch Attribute Editor" but the problem is that one change is for all drawing. I want it to be customsable. Maybe there is an program by it owns that can do this changes? Please help me, and see attached for an example. thats the attributes i want to change. BR Johan Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 1, 2017 Share Posted March 1, 2017 The following should perform as you require, providing the input data is in the expected format: Update Titleblock Attributes. To update multiple drawings, simply run the above with a Script - for this you could use ScriptPro or my Script Writer program. Quote Link to comment Share on other sites More sharing options...
johan Posted March 1, 2017 Author Share Posted March 1, 2017 The following should perform as you require, providing the input data is in the expected format: Update Titleblock Attributes. To update multiple drawings, simply run the above with a Script - for this you could use ScriptPro or my Script Writer program. Hello, I dont really know how to script. I ha ve tried that lips before "updatetitleblock" Havnt got it to work. Is it possible to make an good CSV. file from "extract data" and upload it? Please try and see if you can change the drawing no (or something else) with your tricks. Via excel? See attached. And the red text is what i want to be able to change for example And thanks so much for your answer! /Johan 373KT221.DWG 373KT222.DWG 373KT224.DWG 373KT230.DWG 373V044.DWG Quote Link to comment Share on other sites More sharing options...
