"Mitch" Posted February 27, 2017 Share Posted February 27, 2017 While running in Line command I'm able to snap along the way, snap my running line to itself at each sub prompt: "Specify next point or..." When I try this with the Polyline command, while running polyline at each sub prompt: "Specify next point or..." no snap can be acknowledged. My Polyline won't snap to itself while running toward successive points. All Object Snaps are checked in it's dialog box. Alignment Point Acquisition is set to Automatic. Is there another setting or a system variable that needs to be toggled, maybe something related specifically to Polylines? Quote Link to comment Share on other sites More sharing options...
SunnyTurtle Posted February 28, 2017 Share Posted February 28, 2017 You are using an old style of pline Set PLINETYPE to 1 or 2 to start using the modern type https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Core/files/GUID-F6027128-2707-4BBE-A0A4-C757435D4874-htm.html Quote Link to comment Share on other sites More sharing options...
"Mitch" Posted February 28, 2017 Author Share Posted February 28, 2017 That was it! Thank you. Thank you. Thank you... Quote Link to comment Share on other sites More sharing options...
SunnyTurtle Posted February 28, 2017 Share Posted February 28, 2017 Not a problem happy to help Quote Link to comment Share on other sites More sharing options...
