Mara821 Posted February 27, 2017 Posted February 27, 2017 Hello, how can i set row style for any row in table via AutoLISP? I want to set header for second row too. I found function "vla-getrowtype" in refernce book, but there is no function for set row type. Thanks Quote
Hippe013 Posted February 27, 2017 Posted February 27, 2017 You should dump the properties and methods of the table object. This will give more insight as to what you can do. (defun c:dmpobj () (setq sel (entsel "\nSelect Object: ")) (if sel (vlax-dump-object (vlax-ename->vla-object (car sel)) T) ) (princ) ) Quote
Tharwat Posted February 28, 2017 Posted February 28, 2017 Hi, Since there is not direct function to set the row with a specific text style, so here is my own function to get the job done as required. (defun vla-setrowtextstyle (tbl row sty / col) ;; Tharwat - Date: 28.Feb.2017 ;; (if (and (= (type tbl) 'VLA-OBJECT) (= (vla-get-objectname tbl) "AcDbTable") (>= (vla-get-rows tbl) row) (tblsearch "STYLE" sty) (setq col -1) ) (repeat (vla-get-columns tbl) (vla-setcelltextstyle tbl (1- row) (setq col (1+ col)) sty)) ) (princ) ) ;; eg: (vla-setrowtextstyle tbl 5 "Standard") Quote
Grrr Posted February 28, 2017 Posted February 28, 2017 Nice one, Tharwat! One small suggestion: you could wrap all the evaluations in a single and function. Quote
Tharwat Posted February 28, 2017 Posted February 28, 2017 Nice one, Tharwat! Thank you. One small suggestion: you could wrap all the evaluations in a single and function. Many ways to skin the cat. Quote
Mara821 Posted March 1, 2017 Author Posted March 1, 2017 Hi, Since there is not direct function to set the row with a specific text style, so here is my own function to get the job done as required. (defun vla-setrowtextstyle (tbl row sty / col) ;; Tharwat - Date: 28.Feb.2017 ;; (if (and (= (type tbl) 'VLA-OBJECT) (= (vla-get-objectname tbl) "AcDbTable") (>= (vla-get-rows tbl) row) (tblsearch "STYLE" sty) (setq col -1) ) (repeat (vla-get-columns tbl) (vla-setcelltextstyle tbl (1- row) (setq col (1+ col)) sty)) ) (princ) ) ;; eg: (vla-setrowtextstyle tbl 5 "Standard") This works with text style, but i would like to set row style with acDataRow, acHeaderRow or acTitleRow. It contains: background, text style, text height, alignment. Appearance of table should be depend on table style not text style. Although the result is the same in both ways. Quote
