Qbic Posted February 27, 2017 Posted February 27, 2017 Dear All, I am completely new to autocad programming and want to take professional help or advice for getting the following task completed : 1. Import dxf file 2. Assign measurement data to premitives for tolerance. 3. Import point cloud. 4. Orient point cloud on cad entities. 5. Verify the dimension and generate deviation map 6. Generate inspection report. If someone can help me with this lisp code it will be of great help. Thanks in advance. Quote
SLW210 Posted February 27, 2017 Posted February 27, 2017 I moved your thread to the AutoLISP, Visual LISP & DCL Forum. Please post in the appropriate forum. Please do not use the report button to advertise your posts, the use of the report button is given under the text box Note: This is ONLY to be used to report spam, advertising messages, and problematic (harassment, fighting, or rude) posts. Quote
Hippe013 Posted February 27, 2017 Posted February 27, 2017 (edited) Using a PointCloud is going to be your biggest challenge. The best API for this would be ObjectARX. I believe that most properties and methods of a PointCloud are NOT exposed as of yet through .NET or Visual Lisp (ActiveX). IAcadPointCloud: AutoCAD Point Cloud Interface ; Property values: ; Application (RO) = # ; Document (RO) = # ; EntityTransparency = "ByLayer" ; Handle (RO) = "36A7" ; HasExtensionDictionary (RO) = -1 ; Height = 2364.62 ; Hyperlinks (RO) = # ; InsertionPoint = (0.0 0.0 0.0) ; IntensityColorScheme = 1 ; Layer = "0_Point Cloud" ; Length = 4000.0 ; Linetype = "ByLayer" ; LinetypeScale = 1.0 ; Lineweight = -1 ; Locked = 0 ; Material = "ByLayer" ; Name (RO) = "Point Cloud - (1) (1) (1)" ; ObjectID (RO) = 42 ; ObjectName (RO) = "AcDbPointCloud" ; OwnerID (RO) = 43 ; Path (RO) = AutoCAD.Application: Null object ID ; PlotStyleName = "ByLayer" ; Rotation = 0.0 ; scale = 1.0 ; ShowClipped = -1 ; ShowIntensity = -1 ; Stylization = 0 ; TrueColor = # ; Unit (RO) = "Unitless" ; UnitFactor (RO) = 1.0 ; UseEntityColor = 1 ; Visible = -1 ; Width = 3998.0 ; Methods supported: ; ArrayPolar (3) ; ArrayRectangular (6) ; Copy () ; Delete () ; GetBoundingBox (2) ; GetExtensionDictionary () ; GetXData (3) ; Highlight (1) ; IntersectWith (2) ; Mirror (2) ; Mirror3D (3) ; Move (2) ; Rotate (2) ; Rotate3D (3) ; ScaleEntity (2) ; SetXData (2) ; TransformBy (1) ; Update () 0 Edited February 27, 2017 by Hippe013 Typo Quote
Qbic Posted February 28, 2017 Author Posted February 28, 2017 Thanks a lot sir for your reply. It now gives me good confidence on feasibility of this concept. If any programmer who is ready to take this up as a professional development work please let me know. I am ready to avail their services. Sorry if I am violating any norms cause I am totally new to this. Quote
satishrajdev Posted February 28, 2017 Posted February 28, 2017 Hi, I've read your scope and can provide complete solution to that. As I can see you are from India. You can have direct discussion on phone as well. I'm mailing you my contact details Or you can PM me you contact details. Regards, Satish Quote
Qbic Posted February 28, 2017 Author Posted February 28, 2017 sorry for that mistake. will ensure the same in future. Quote
