AutoCAD LT 2012 Slowness and Lagging
Hi,
I just joined the Forums today, looks like there is plenty of knowledge here. I'm hoping some of the experts can lend a hand with my slow/laggy experience with some CAD Drawings. Here is some info to get started, let me know what else you may need if i missed something.
System Information
CAD Version: AutoCAD LT 2012
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.161011-0600)
Language: English (Regional Setting: English)
System Manufacturer: LENOVO
System Model: 20AQ005VUS
BIOS: Phoenix BIOS SC-T v2.1
Processor: Intel® Core™ i5-4300U CPU @ 1.90GHz (4 CPUs), ~2.5GHz
Memory: 12288MB RAM
Available OS Memory: 11976MB RAM
Page File: 10583MB used, 13364MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
Display Devices
Card name: Intel® HD Graphics Family
Manufacturer: Intel Corporation
Chip type: Intel® HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0A16&SUBSYS_220C17AA&REV_0B
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LG IPS FULLHD
Monitor Id: GSM5AB6
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: Displayport External
Typically my CAD files are anywhere from 250kb to 4mb no greater.
Thanks in advance, looking forward to the replies.
This is a Thinkpad 440s?
Has LT always been slow and lagging or are these symptoms recent?
Is hardware acceleration enabled?
Just double checking here. There is 12GB of RAM installed?
My initial guess would be it has something to do with the onboard graphics chip which is entry level at best. A dedicated graphics card would be a better choice
Hi,
System Information
Memory: 12288MB RAM
Display Devices
DAC type: Internal
Monitor Id: GSM5AB6
I'm with Remark. The BOLD above could very well be your issue. Do you attach xrefs, for instance PDF pages? They burn Video memory up.
Do you have AutoSave set on something like 5 minutes?
Everyone trying to run on an an on board graphics processor eventually has similar problems. If my memory serves me correctly 2012 LT needs at least 2 gig of video (display) memory.
I am not aware of any after-market video upgrades for a thinkpad.
I believe it can be upgraded by changing out the board to the one with an NVidia card on it. Probably cost prohibitive, but possible.
Changing out a motherboard on a laptop has to be the ultimate fun way to spend a weekend.:shock::lol:
Good Morning,
Sorry, It took me until today to respond, in the slow season I typically don't bring my work laptop home for the weekend (no reason too!). Here are the Responses below, I attempted to keep them in order from earliest to latest:
1. Correct, the model is a ThinkPad 440s.
2. To my knowledge, the symptoms have always been present on larger file size dwgs, not really on smaller, much simpler drawings. I will admit it is tough for me to scale as sometimes I go awhile without using CAD on my computer, depends on the timeline and project.
3. Hardware Acceleration is off and unavailable with my current graphics specs.
4. 12GB RAM is installed.
5. Unfortunately, with this laptop, I can't go gutting it since it is company property. The only option that exists for me is asking for an upgraded device for CAD use. They would probably shut it down because my CAD use is so sporadic and usually when I do use it, it doesn't end up being very onerous.
6. I do attached PDFs sometimes, I notice a much more drastic slowdown with that function.
7. Autosave function interval, I'm actaully not sure what it is set at. I have never tinkered with it. Not sure how...... is it a setting or command?
Re: larger drawing file sizes. Do you regularly clean up your drawings using such commands as Overkill, -Purge and Audit? Such procedures can sometimes reduce the file size. Do you use content from any outside sources?
I don't use those commands often. Gave them a try on a 1mb drawing that was lagging after drawing a line. Didn't notice any change.
In terms of outside sources, I don't believe so........... Can you clarify what you mean by that?
Can you attach a copy of one of your larger file size drawings? You can strip out any information regarding the company name/location.
Outside sources....as in do you get drawings from other companies that you then use directly (by adding your own content) or that you "borrow" from as in copy/paste from their drawing to yours. I'm looking for the presence of any Microstation (.DGN) linetypes which can lead to file bloat.
