Hi..Everyone.
I need help again. I have a lisp code for create layouts automatically.
I have a rectangle attribute block. First I insert the block in model space then run the lisp.
This lisp creates a layouts according to block insertion point.
Layouts creates properly but it creates reverse order
For ex.. I have insert 3 blocks and layouts should be creates like A01,A02,A03, but its create like reverse order (A03,A02,A01)
I want to layout create like A01,A02,A03…etc.
Someone help me.
(defun c:Aplan()
(vl-load-com)
(vlax-for layout (vla-get-layouts
(vla-get-ActiveDocument (vlax-get-acad-object))
(if (/= (vla-get-name layout) "Model")
(vla-delete layout)
(command "filedia" "1")
(setq ss (ssget "X" '((2 . "A3") (66 . 1))))
(setq no_of_blocks(sslength ss))
(setq test 0)
(while (< test no_of_blocks)
(setq ent(ssname SS test))
(setq enx (entget (setq blk (entnext ent))))
(Setq entp (entget ent))
(setq inspoint (item 10 entp))
(setq vname (item 1 enx))
(print (type vname))
(command "tilemode" "1")
(command "-view" "w" vname inspoint "@396.0000,204.6493")
(command "_layout" "template" "C:/User/Desktop/Template.dwg" "A3")
(command "_layout" "set" "A3")
(command "_layout" "rename" "A3" (strcat "A" vname ""))
(command "mspace" "-view" "r" vname )(command "pspace")
(command "-view" "d" vname)
(setq test (1+ test))
(terpri)
(command "layout" "d" "layout1")
(command "layout" "d" "layout2")
(command "regenall")
(Defun ITEM (N E) (CDR (Assoc N E)))
A3.dwg[/ATTACH]
Template.dwg
Look at this method it works in reverse for the selection set
(setq ent (ssname SS (setq (setq x (- x 1))))) this will get to 0 item
Edited by SLW210
