export multiple shapefiles into one
I have 2 shapefiles I need to export into one... I used the map import for both bringing in the data with them which all data shows up in the properties. All good. When I use mapexport to try and combine them, I pick all attributes from both files and export, but when I re-import into a clean drawing I get 2 sets of polylines still with original attributes. What I need is one set of polylines with all attributes from both original files linked to one set of polylines. Does this make sense?? And how in the heck can I get this to work?? I must have done this a thousand times with the same result...it's driving me mad!! Civil 3d 2012
