eldon Posted February 15, 2017 Posted February 15, 2017 oftenly said: Here you go: ellipse.zip....... One small point of query, is the shape in your posted drawing an ellipse? I had to convert the drawing to be able to open it, and the shape that I saw was a polyline consisting of many small lines. When I tried to draw an ellipse from your axes, the shape did not match yours. Quote
lrm Posted February 15, 2017 Posted February 15, 2017 In the drawing that the OP posted the "ellipses" were actually polylines. I imagine that at some point the ellipse he was working with was converted to a polyline. It is worthwhile to note that mathematically, the offset to an ellipse is not an ellipse. This is why when offset is used on an ellipse in AutoCAD a spline is created. It is best to work with a true ellipse entity or a spline as osnap tan can be used. The maximum deviation between a true ellipse and the polyline curve in the drawing is less than 0.2%. Quote
BIGAL Posted February 16, 2017 Posted February 16, 2017 I opened the dwg file and like everyone else its small line segments for that reason the code I posted will work. It will need to be edited for distance bewteen objects and how the object is placed but the method is usable and simple. I tested ellipse's a few problems cropped up. I did think about going to first principles and produce what has been supplied a short segment pline. Quote
steven-g Posted February 16, 2017 Posted February 16, 2017 Not wanting to be left out, here is a visual method for getting the ellipse focus points (you have to place the points manually using the intersect osnap - doing that in a dynamic block is beyond my brain power). And a second Dynamic block that I use for disecting angles, I just added a few notes into it to hopefully show how it works. Otherwise just ask Ellipse and bisect.dwgFetching info... Quote
