BHAInc Posted February 8, 2017 Posted February 8, 2017 Is there a more efficient way to write the following code? Thanks in advance for any suggestions. (mapcar (function (lambda (l) (vl-catch-all-apply 'vla-addline l)) ) (list (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(0.5 1.0 0.0)) (vlax-3d-point '(8.0 1.0 0.0)) ) (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(0.0 0.0 0.0)) (vlax-3d-point '(8.5 0.0 0.0)) ) (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(0.0 11.0 0.0)) (vlax-3d-point '(0.0 0.0 0.0)) ) (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(0.5 10.5 0.0)) (vlax-3d-point '(0.5 1.0 0.0)) ) (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(8.0 1.0 0.0)) (vlax-3d-point '(8.0 10.5 0.0)) ) (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(8.5 0.0 0.0)) (vlax-3d-point '(8.5 11.0 0.0)) ) (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(0.5 10.5 0.0)) (vlax-3d-point '(8.0 10.5 0.0)) ) (list (vla-get-paperspace (acdoc)) (vlax-3d-point '(0.0 11.0 0.0)) (vlax-3d-point '(8.5 11.0 0.0)) ) ) ) Quote
Grrr Posted February 8, 2017 Posted February 8, 2017 (edited) (mapcar '(lambda (x) (entmakex (list '(0 . "LINE") (cons 10 (car x)) (cons 11 (cadr x))))) '( ((0.5 1.0 0.0) (8.0 1.0 0.0)) ((0.0 0.0 0.0) (8.5 0.0 0.0)) ((0.0 11.0 0.0) (0.0 0.0 0.0)) ((0.5 10.5 0.0) (0.5 1.0 0.0)) ((8.0 1.0 0.0) (8.0 10.5 0.0)) ((8.5 0.0 0.0) (8.5 11.0 0.0)) ((0.5 10.5 0.0) (8.0 10.5 0.0)) ((0.0 11.0 0.0) (8.5 11.0 0.0)) ) ) ) EDIT: For 2D points (on zero elevation), maybe something like this: (mapcar '(lambda (x) (entmakex (mapcar 'cons '(0 10 11) (append '("LINE") (mapcar 'append x (mapcar 'list '(0. 0.))))))) '( ((0.5 1.0) (8.0 1.0)) ((0.0 0.0) (8.5 0.0)) ((0.0 11.0) (0.0 0.0)) ((0.5 10.5) (0.5 1.0)) ((8.0 1.0) (8.0 10.5)) ((8.5 0.0) (8.5 11.0)) ((0.5 10.5) (8.0 10.5)) ((0.0 11.0) (8.5 11.0)) ) ) HTH, I was bored. Edited February 8, 2017 by Grrr Quote
BIGAL Posted February 8, 2017 Posted February 8, 2017 (edited) Maybe make 1 big list ((pt1)(pt2)(pt1)(pt2).....) get length of the list then use repeat, Ok a question if its a 4 sided box just done twice why not use rectang 2 pts only required. (setq lst (list (list 0.5 1.0 0.0) (list 8.0 1.0 0.0) (list 0.0 0.0 0.0) (list 8.5 0.0 0.0) (list 0.0 11.0 0.0) (list 0.0 0.0 0.0) (list 0.5 10.5 0.0) (list 0.5 1.0 0.0) (list 8.0 1.0 0.0) (list 8.0 10.5 0.0) (list 8.5 0.0 0.0) (list 8.5 11.0 0.0) (list 0.5 10.5 0.0) (list 8.0 10.5 0.0) (list 0.0 11.0 0.0) (list 8.5 11.0 0.0) )) (setq x (length lst)) (repeat (/ (length lst) 2) (command "line" (nth (- x 2) lst) (nth (- x 1) lst) "") (setq x (- x 2)) ) my preference 5 lines long (setq oldsnap (getvar "osmode")) (setvar "osmode" 0) (command "rectang" (list 0.5 1.0) (list 8.0 10.5)) (command "rectang" (list 0.0 0.0) (list 8.5 11.0)) (setvar "osmode" oldsnap) Edited February 8, 2017 by BIGAL Quote
Lee Mac Posted February 8, 2017 Posted February 8, 2017 I would suggest two lists: (mapcar '(lambda ( a b ) (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 b)))) '((0.5 1.0)(0.0 0.0)(0.0 11.0)(0.5 10.5)(8.0 1.0)(8.5 0.0)(0.5 10.5)(0.0 11.0)) '((8.0 1.0)(8.5 0.0)(0.0 0.0)(0.5 1.0)(8.0 10.5)(8.5 11.0)(8.0 10.5)(8.5 11.0)) ) Quote
BHAInc Posted February 8, 2017 Author Posted February 8, 2017 Excellent! Thank you for all for the suggestions and replies, they're very helpful. In the name of academic curiosity, is anyone able to suggest a more efficient way to write the code while using the "vla-addline" function? Thanks in advance. Quote
marko_ribar Posted February 8, 2017 Posted February 8, 2017 Copy+pasted lists from Lee... (mapcar (function (lambda ( a b ) (vla-addline (vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point a) (vlax-3d-point b)))) '((0.5 1.0)(0.0 0.0)(0.0 11.0)(0.5 10.5)(8.0 1.0)(8.5 0.0)(0.5 10.5)(0.0 11.0)) '((8.0 1.0)(8.5 0.0)(0.0 0.0)(0.5 1.0)(8.0 10.5)(8.5 11.0)(8.0 10.5)(8.5 11.0)) ) Quote
Lee Mac Posted February 8, 2017 Posted February 8, 2017 marko_ribar said: Copy+pasted lists from Lee... (mapcar (function (lambda ( a b ) (vla-addline (vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point a) (vlax-3d-point b)))) '((0.5 1.0)(0.0 0.0)(0.0 11.0)(0.5 10.5)(8.0 1.0)(8.5 0.0)(0.5 10.5)(0.0 11.0)) '((8.0 1.0)(8.5 0.0)(0.0 0.0)(0.5 1.0)(8.0 10.5)(8.5 11.0)(8.0 10.5)(8.5 11.0)) ) You realise that this is needlessly retrieving the Paperspace Container, Active Document Object and Application Object for every line created!? These objects need only be obtained once and referenced locally, e.g.: ( (lambda ( spc ) (mapcar '(lambda ( a b ) (vlax-invoke spc 'addline a b)) '((0.5 1.0 0.0)(0.0 0.0 0.0)(0.0 11.0 0.0)(0.5 10.5 0.0)(8.0 1.0 0.0)(8.5 0.0 0.0)(0.5 10.5 0.0)(0.0 11.0 0.0)) '((8.0 1.0 0.0)(8.5 0.0 0.0)(0.0 0.0 0.0)(0.5 1.0 0.0)(8.0 10.5 0.0)(8.5 11.0 0.0)(8.0 10.5 0.0)(8.5 11.0 0.0)) ) ) (vla-get-paperspace (vla-get-activedocument (vlax-get-acad-object))) ) Quote
Grrr Posted February 9, 2017 Posted February 9, 2017 Also its a smart thing to avoid the point safearray conversion by using vlax-invoke, just like Lee did, but for obtaining the container with model/paper space entities I think that this would be more suitable: (or (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)) AcSpc (vlax-get acDoc (if (= acModelSpace (vla-get-ActiveSpace acDoc)) 'ModelSpace (if (= (vla-get-mSpace acDoc) :vlax-true) 'ModelSpace 'PaperSpace))) ) (vla-get-Block (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))) ) I mean either obtain the Mspace/Pspace by checking or directly access the block (I got used with the or funciton to write alternatives inside the code). Quote
BIGAL Posted February 9, 2017 Posted February 9, 2017 I tried to find a vla-addrectang does it exist ? vla-addLightweightPolyline does exist, so can pass the 4 points. Quote
Grrr Posted February 9, 2017 Posted February 9, 2017 (edited) BIGAL said: I tried to find a vla-addrectang does it exist ? vla-addLightweightPolyline does exist, so can pass the 4 points. Yeah, basically the result from the RECTANGLE command is a lwpolyline, i.e. when you dump a rectangle the first row is: ; IAcadLWPolyline: AutoCAD Lightweight Polyline Interface just like entgetting the same thing should result (0 . "LWPOLYLINE"), so theres no such thing as rectangle method or entmaking an rectangle. But you're leaving the idea for creating such subfunction that would add/emake rectangle lwpoly from a 2 points argument (lowerleft upperright). EDIT: BTW heres another (with command calls) similar to yours: ( (lambda (c) (setvar 'cmdecho 0) (foreach x '(((0. 0. 0.) (8.5 11 0)) ((0.5 1.) (7.5 9.5 0))) (command "_.RECTANGLE" "_non" (car x) "_non" (mapcar '+ (car x) (cadr x))) ) (setvar 'cmdecho c) ) (getvar 'cmdecho) ) Edited February 9, 2017 by Grrr Quote
BHAInc Posted February 9, 2017 Author Posted February 9, 2017 Thank you again for all of the suggestions and replies. Very informative. Quote
BIGAL Posted February 10, 2017 Posted February 10, 2017 Your right Grr I think the bottom line without continuing on is "do you want individual lines or rectangs" so both have been covered with different methods.. Quote
