H_Feather Posted February 2, 2017 Posted February 2, 2017 I have a lisp to change an object to what layer I need it to be on. The layer name, color and linetype I have figured out. The only thing is some layers will need a different lineweight rather than default. For an example layer (as below) the Ancillary layer is suppose to be at .40 for lineweight. Where or how do I need to put in my current lisp the specific lineweight? Thanks for any help. (defun c:CLA ( / CLAYER SS) ;;Changes lines to the ANCILLARY layer (princ "\nPick objects to be changed to the ANCILLARY layer: ") (setq CLAYER (getvar "clayer")) (setq SS (ssget)) (if SS(command ".layer" "make" "ANCILLARY" "c" "200" "ANCILLARY" "ltype" "continuous" "ANCILLARY" "set" CLAYER "" ".change" SS "" "p" "layer" "ANCILLARY" "color" "bylayer" "lt" "bylayer" "") (princ "\nNothing selected")) (princ)) Quote
mwade93 Posted February 2, 2017 Posted February 2, 2017 You should be able to add in a line of code in the layer command you have existing when you are making your layer. Use "LW" "0.40" "Layer-Name". I'm curious why are you using the change command instead of the options you get under the layer command? I have a lisp to change an object to what layer I need it to be on. The layer name, color and linetype I have figured out. The only thing is some layers will need a different lineweight rather than default. For an example layer (as below) the Ancillary layer is suppose to be at .40 for lineweight. Where or how do I need to put in my current lisp the specific lineweight? Thanks for any help. (defun c:CLA ( / CLAYER SS) ;;Changes lines to the ANCILLARY layer (princ "\nPick objects to be changed to the ANCILLARY layer: ") (setq CLAYER (getvar "clayer")) (setq SS (ssget)) (if SS(command ".layer" "make" "ANCILLARY" "c" "200" "ANCILLARY" "ltype" "continuous" "ANCILLARY" "set" CLAYER "" ".change" SS "" "p" "layer" "ANCILLARY" "color" "bylayer" "lt" "bylayer" "") (princ "\nNothing selected")) (princ)) Quote
Tharwat Posted February 2, 2017 Posted February 2, 2017 Here... "ltype" "continuous" "ANCILLARY" [color="magenta"]"LWeight" "0.4" ""[/color] "set" ....... Quote
H_Feather Posted February 2, 2017 Author Posted February 2, 2017 Here... "ltype" "continuous" "ANCILLARY" [color="magenta"]"LWeight" "0.4" ""[/color] "set" ....... Sweet! Tharwat saves the day! Thanks again Quote
Tharwat Posted February 2, 2017 Posted February 2, 2017 Sweet! Tharwat saves the day! Thanks again You are most welcome. Quote
H_Feather Posted February 2, 2017 Author Posted February 2, 2017 You should be able to add in a line of code in the layer command you have existing when you are making your layer. Use "LW" "0.40" "Layer-Name". I'm curious why are you using the change command instead of the options you get under the layer command? Just how I was trained I guess. Quote
Tomislav Posted June 20, 2022 Posted June 20, 2022 And I have a question, how do I get LW of current layer, I've tried with lyr_lw(cdr (assoc 370 (tblsearch "layer" current_lyr))) but just getting nil Quote
exceed Posted June 20, 2022 Posted June 20, 2022 1 hour ago, Tomislav said: And I have a question, how do I get LW of current layer, I've tried with lyr_lw(cdr (assoc 370 (tblsearch "layer" current_lyr))) but just getting nil (vl-load-com)(vlax-get-property (vla-Item (vla-get-Layers (vla-get-ActiveDocument (vlax-get-Acad-Object))) (getvar 'clayer)) 'lineweight) try this Quote
Tomislav Posted June 20, 2022 Posted June 20, 2022 5 minutes ago, exceed said: (vl-load-com)(vlax-get-property (vla-Item (vla-get-Layers (vla-get-ActiveDocument (vlax-get-Acad-Object))) (getvar 'clayer)) 'lineweight) try this thank you for fast response, it works! I was trying something with vla-... also, but I'm not that good with activex Quote
exceed Posted June 20, 2022 Posted June 20, 2022 (edited) 7 minutes ago, Tomislav said: thank you for fast response, it works! I was trying something with vla-... also, but I'm not that good with activex (cdr (assoc 370 (entget (tblobjname "layer" (getvar 'clayer))))) or you can do with dxf list like this way reason = cannot get the assoc 370 in tblsearch list becasue that is not a whole list. that is symbol list. like when you make entity by entmake, in example (setq a (entmake ~~~)) (princ a) this list also not contain ename, so, (entmakex ~~) is better to control that with ename. so, get ename by (tblobjname) is better in your case. i think Edited June 20, 2022 by exceed Quote
Tomislav Posted June 20, 2022 Posted June 20, 2022 well, this two lines worked lyr_col(cdr (assoc 62 (tblsearch "layer" c_lyr))); Layer color lyr_lt(cdr (assoc 6 (tblsearch "layer" c_lyr))); Layer line type and that's why i tried like so for LW, but like you said, it seems that LW must be done through tblobjname Quote
exceed Posted June 20, 2022 Posted June 20, 2022 1 minute ago, Tomislav said: well, this two lines worked lyr_col(cdr (assoc 62 (tblsearch "layer" c_lyr))); Layer color lyr_lt(cdr (assoc 6 (tblsearch "layer" c_lyr))); Layer line type and that's why i tried like so for LW, but like you said, it seems that LW must be done through tblobjname Command: (tblsearch "layer" (getvar 'clayer)) ((0 . "LAYER") (2 . "0") (70 . 0) (62 . 7) (6 . "Continuous")) Command: (entget (tblobjname "layer" (getvar 'clayer))) ((-1 . <ENTITY NAME: ec1021a8>) (0 . "LAYER") (5 . "10") (330 . <ENTITY NAME: ec102058>) (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2 . "0") (70 . 0) (62 . 7) (6 . "Continuous") (290 . 1) (370 . -3) (390 . <ENTITY NAME: ec102190>) (347 . <ENTITY NAME: ec104350>) (348 . <ENTITY NAME: 0>) (1071 . 33554687)) yes, this difference make that situation. assoc is simple function, get member of list. so, for debug that, have to test inner side like above two command. in this case, tblsearch's list will response only assoc 0, 2, 70, 62, 6. and entget tblobjname will response assoc -1, 0, 5, 330, 100, 2, 70, 62, 6, 290, 370, 390, 347, 348, 1071 Quote
Tomislav Posted June 20, 2022 Posted June 20, 2022 yes, LW is in 'parent' list, thank you again for your explanation 1 Quote
