samifox Posted February 1, 2017 Posted February 1, 2017 hi Having wearied problem e-transmitting a projectמ on LT. Executing the e-transmit command, the hierarchy tree is blank, Pressing OK start running the process, but freezes Cancelling the transmit command and then trying to save yell error "DBX CAS 4" It happens regardless of the LT version In the Full vanilla AutoCAD its behave normally Thanks S Quote
