whosa Posted January 19, 2017 Share Posted January 19, 2017 (edited) Hi, i would like to make rectangle (or close polyline) inside a 3d solid. Right now i use: Ucs + Face + first corner of rectangle and second corner of rectangle. I would like to do this by lisp. Something like: 1st click: first corner 2nd click: second corner Drawing a rectangle whit two point meaning the yellow edge of the rectangle must to be parallel to z axis. If someone can help me would be great. Thanks Edited January 19, 2017 by whosa Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 20, 2017 Share Posted January 20, 2017 UCS X 90 maybe Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted January 20, 2017 Share Posted January 20, 2017 Try: (defun c:3DRect ( / doc firstP normal pt1 pt2 pt3 pt4) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) ; End open undo group. (vla-startundomark doc) (if (and (setq pt1 (getpoint "\nFirst corner: ")) (setq pt3 (getpoint pt1 "\nOther corner: ")) (setq normal (mapcar '(lambda (a b) (if (equal a b 1e- 1 0)) pt1 pt3) ) (= 1 (apply '+ normal)) ) (progn (setq pt2 (mapcar '(lambda (n a b) (cond ((= 1 n) a) ((setq firstP (not firstP)) a) (b)) ) normal pt1 pt3 ) ) (setq pt4 (mapcar '(lambda (n a b) (cond ((= 1 n) a) ((setq firstP (not firstP)) a) (b)) ) normal pt3 pt1 ) ) (setq normal (trans normal 1 0 T)) (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 4) (cons 70 (+ 1 (* (getvar 'plinegen) 128))) (cons 43 (getvar 'plinewid)) (cons 38 (caddr (trans pt1 1 normal))) ; Elevation. (cons 39 (getvar 'thickness)) (cons 10 (trans pt1 1 normal)) (cons 10 (trans pt2 1 normal)) (cons 10 (trans pt3 1 normal)) (cons 10 (trans pt4 1 normal)) (cons 210 normal) ) ) ) ) (vla-endundomark doc) (princ) ) Quote Link to comment Share on other sites More sharing options...
whosa Posted January 22, 2017 Author Share Posted January 22, 2017 Try: (defun c:3DRect ( / doc firstP normal pt1 pt2 pt3 pt4) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) ; End open undo group. (vla-startundomark doc) (if (and (setq pt1 (getpoint "\nFirst corner: ")) (setq pt3 (getpoint pt1 "\nOther corner: ")) (setq normal (mapcar '(lambda (a b) (if (equal a b 1e- 1 0)) pt1 pt3) ) (= 1 (apply '+ normal)) ) (progn (setq pt2 (mapcar '(lambda (n a b) (cond ((= 1 n) a) ((setq firstP (not firstP)) a) (b)) ) normal pt1 pt3 ) ) (setq pt4 (mapcar '(lambda (n a b) (cond ((= 1 n) a) ((setq firstP (not firstP)) a) (b)) ) normal pt3 pt1 ) ) (setq normal (trans normal 1 0 T)) (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 4) (cons 70 (+ 1 (* (getvar 'plinegen) 128))) (cons 43 (getvar 'plinewid)) (cons 38 (caddr (trans pt1 1 normal))) ; Elevation. (cons 39 (getvar 'thickness)) (cons 10 (trans pt1 1 normal)) (cons 10 (trans pt2 1 normal)) (cons 10 (trans pt3 1 normal)) (cons 10 (trans pt4 1 normal)) (cons 210 normal) ) ) ) ) (vla-endundomark doc) (princ) ) Many Thanks for it, i tried it. It partially work. I tried to use in many case but some time doesn't work. Attached you can find the test. In three cases (red polyline) this lisp doesn't work. Maybe i make some mistake. test.dwg Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted January 22, 2017 Share Posted January 22, 2017 Here, I've corrected Roy's code, although it's somewhat different, but logic is the same... (defun c:3DRect ( / v^v unit doc normal pt1 pt2 pt3 pt4 ) (vl-load-com) (defun v^v ( u v ) (list (- (* (cadr u) (caddr v)) (* (caddr u) (cadr v))) (- (* (caddr u) (car v)) (* (car u) (caddr v))) (- (* (car u) (cadr v)) (* (cadr u) (car v))) ) ) (defun unit ( v ) (if (not (equal v '(0.0 0.0 0.0) 1e-) (mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v) ) ) (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-endundomark doc) ; End open undo group. (vla-startundomark doc) (if (and (setq pt1 (trans (getpoint "\nFirst corner : ") 1 0)) (setq pt3 (trans (getpoint (trans pt1 0 1) "\nOther corner : ") 1 0)) (setq normal (unit (v^v '(0.0 0.0 1.0) (mapcar '- pt3 pt1)))) ) (progn (setq pt2 (inters pt1 (mapcar '+ pt1 (v^v normal (append (mapcar '+ '(0.0 0.0) (mapcar '- pt3 pt1)) (list 0.0)))) pt3 (mapcar '+ pt3 (append (mapcar '+ '(0.0 0.0) (mapcar '- pt1 pt3)) (list 0.0))) nil)) (setq pt4 (inters pt3 (mapcar '+ pt3 (v^v normal (append (mapcar '+ '(0.0 0.0) (mapcar '- pt1 pt3)) (list 0.0)))) pt1 (mapcar '+ pt1 (append (mapcar '+ '(0.0 0.0) (mapcar '- pt3 pt1)) (list 0.0))) nil)) (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") '(90 . 4) (cons 70 (+ 1 (* (getvar 'plinegen) 128))) (cons 43 (getvar 'plinewid)) (cons 38 (caddr (trans pt1 0 normal))) ; Elevation. (cons 39 (getvar 'thickness)) (cons 10 (trans pt1 0 normal)) (cons 10 (trans pt2 0 normal)) (cons 10 (trans pt3 0 normal)) (cons 10 (trans pt4 0 normal)) (cons 210 normal) ) ) ) ) (vla-endundomark doc) (princ) ) M.R. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted January 22, 2017 Share Posted January 22, 2017 My interpretation of the problem is different from Marko's. My code assumes the rectangle must be drawn parallel to the X, Y or Z plane of the current UCS. Marko's solution assumes that two sided of the rectangle must be parallel to the Z-axis of the WCS. Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted January 22, 2017 Share Posted January 22, 2017 @Marko: Why don't you calculate pt2 and pt4 like this?: (setq pt2 (list (car pt1) (cadr pt1) (caddr pt3))) (setq pt4 (list (car pt3) (cadr pt3) (caddr pt1))) Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted January 23, 2017 Share Posted January 23, 2017 @Marko:Why don't you calculate pt2 and pt4 like this?: (setq pt2 (list (car pt1) (cadr pt1) (caddr pt3))) (setq pt4 (list (car pt3) (cadr pt3) (caddr pt1))) Yes, it's simple as that... I over programmed the code, but result is the same - always many ways to skin the cat... Quote Link to comment Share on other sites More sharing options...
