Hello guys,
I'm trying to make a lisp to import points from txt file to autocad, and then to polyline them and to make a union from those points, creating a iregular area. The main purpose is to calculate the area of this created object.
The txt file is something like this:
101 234.442 442.425
102 .....
103....
104...
105...
Anyone there that could help me with this lips ? I kinda need it until tomorow.
Quickest way open file in excel, use space as delimeter.
make a blank line at top put PLINE in cell E1
Then use =concatenate(b2,",",c2) in cell E2
copy the formula all way down as required
you should have
pline
x,y
x,y
x,y etc
Just copy column E and paste to autocad command line.
Yes can do a lisp but this is just as fast.
You can try this :-
(defun c:impnt (/ str->list a b c cm d s)
 (defun str->list (str / b)
   (foreach x (reverse (vl-string->list str))
     (cond ((eq x 44) (setq b (cons (list x) b)))
    (t
     (if (not b)
       (setq b (cons (cons x (car b)) (cdr b)))
   (setq b (mapcar '(lambda (x) (vl-list->string (vl-remove 44 x))) b))
   (if	(and (> (length b) 1)
     (numberp (read (car b)))
     (numberp (read (cadr b)))
     (numberp (read (caddr b)))
     (list (atof (car b)) (atof (cadr b)) (atof (caddr b)))
 (if
   (and (setq
   a (getfiled "Select CSV File" (getvar "dwgprefix") "txt;csv" 16)
 (setq s (getdist "\nSpecify Point Size : "))
 (setq a (open a "r"))
 (setq c (while	(setq b (read-line a))
	   (setq c (cons (str->list b) c))
      (close a)
      (setq cm (getvar 'cmdecho))
      (setvar 'cmdecho 0)
      (setvar 'pdmode 35)
      (setvar 'pdsize s)
      (setq d (ssadd)
     c (vl-remove nil c)
      (foreach	x c
 (ssadd	(entmakex (list	(cons 0 "POINT")
			(cons 62 3)
			(cons 10 x)
	d
      (ssadd (entmakex
	(append	(list (cons 0 "LWPOLYLINE")
		      (cons 100 "AcDbEntity")
		      (cons 100 "AcDbPolyline")
		      (cons 90 (length c))
		      (cons 70 1)
		(mapcar (function (lambda (p) (cons 10 p))) c)
      d
      (command "_.zoom" "_o" d "")
      (setvar 'cmdecho cm)
      (sssetfirst nil d)
The TXT/CSV format should be like this. Program skips the header automatically.
Easting (x),Northing (Y),Elevation (Z)
373247.97,2051482.34,0
373271.02,2051446.02,0
373215.57,2051471.86,0
373210.14,2051497.24,0
satishrajdev 2 things csv file in 1st post is Ptnum X Y so need to strip off the point number, 2nd is he wants to make a pline of the points so question is do you really need the points ? As you are using "car cadr & caddr" you can drop the "car" which will be the pt number.
As per my post
pline
x,y
x,y
If want both then do a double pass import points then 2nd pass make pline.
  satishrajdev said:
You can try this :-
    (t
     (if (not b)
 (if
   (and (setq
      (close a)
      (setvar 'cmdecho 0)
      (setvar 'pdmode 35)
      (setvar 'pdsize s)
      (setq d (ssadd)
     c (vl-remove nil c)
      (foreach	x c
			(cons 62 3)
			(cons 10 x)
	d
      (ssadd (entmakex
		      (cons 70 1)
      d
      (sssetfirst nil d)
Thanks for that awesome help. I'm trying to make it on education purpose for my faculty.
I will check it out but untill now it worked perfectly.
have a nice day.
I know, I wrote this routine for someone and posted it directly. I have modified following code as per OP's requirement.
    (t
     (if (not b)
     (numberp (read (cadddr b)))
     (list (atof (cadr b)) (atof (caddr b)) (atof (cadddr b)))
 (if
   (and (setq
      (close a)
      (setvar 'cmdecho 0)
      (setvar 'pdmode 35)
      (setvar 'pdsize s)
      (setq d (ssadd)
     c (vl-remove nil c)
      (foreach	x c
			(cons 62 3)
			(cons 10 x)
	d
      (ssadd (entmakex
		      (cons 70 1)
      d
      (sssetfirst nil d)
Another one without point entities:
(defun c:impnt (/ str->list a c cm d)
    (t
     (if (not b)
 (if
   (and (setq
	       "txt;csv"
	       16
      (close a)
      (setvar 'cmdecho 0)
      (setq d (ssadd)
     c (vl-remove nil c)
      (ssadd (entmakex
		      (cons 70 1)
      d
      (sssetfirst nil d)
have a nice day.
You're welcome :):)
Satishrajdev thats the problem with survey csv files they can be all over the place in CIV3D you have styles so nominate how the csv looks P,x,y,z,d etc.
The import a csv and string it based on codes is still on my list to do one day.
  BIGAL said:
.. P,x,y,z,d etc.
8) 1+
  satishrajdev said:
[color="green"]..
...[/color]
vlisp suggestion vl-every
[color="green"] (list (atof (cadr b)) (atof (caddr b)) (atof (cadddr b)))[/color]
FYI try mapcar ;)
