VBA CODE-From multiple areas to plot in model space to create a layout for each areas
Hi everybody,
I have a big problem....
I have about 100 DWG with a lot of sheet in the same model space and i must print every sheet, so i am looking for a script in VBA or lisp to create from multiple areas to plot in model space, a layout tab for each area vba autocad.
I found a lisp script, but it doesn't run (plotDWGarr).
(http://www.cadforum.cz/cadforum_en/plotting-a-series-of-drawing-frames-composed-in-a-dwg-drawing-tip7585)
Do you know another similar script o to write a VBA to do it?
Thank you very much in advance
If I understand correct this will plot all sheets in model space rather than trying to redo all of them.
; plot multi title block in Model space
; By Alan H 2013
(PROMPT ".....PRINTING DRAWING TO plotter....")
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 0)
(setq ss2 (ssget "x" '((0 . "INSERT")(2 . "Da1drsht"))))
(setq n (sslength ss2))
(setq index 0)
(repeat n
   (setq en (ssname ss2 index))
   (setq el (entget en))
   (setq inspt (assoc 10 el)) ; insertion pt
  (setq xmin (- (cadr inspt) 6.0))
  (setq ymin (- (caddr inspt) 6.0))
  (setq xymin (strcat (rtos xmin 2 1) "," (rtos ymin 2 1)))
  (setq xmax (+ xmin 813.0)) ; hard coded for 813 wide 6mm offset
  (setq ymax (+ ymin 566.0)) ;hard code for 566 high
  (setq xymax (strcat (rtos xmax 2 1) "," (rtos ymax 2 1)))
 (COMMAND "-PLOT"  "Y"     "" "//PRODPRN01/Design-5100"
       "A3" "M"     "LANDSCAPE"   "N"
       "W"   xymin   xymax "1=2"  "C"
       "y"   "Designlaser.ctb"      "Y"   "" "n"   "n"
       "y" "N" "N" "Y"
 (setq index (+ index 1))
(setvar "osmode" oldsnap)
Edited by BIGAL
For Bigal:
Thank you very much Bigal, after i will try if it runs or no.
However i prefer use a VBA for this script
For Maratovich:
Excuse me, here the example.
Example Model (1).pdf
Example.rar
For Bigal:
Excuse me Bigal for my ignorance, but how can i use your script, because i tried, but AutoCad told me that there are some problems.
Can you tell me what steps i must do to load and to use your script??^^
Thank you very much :).
I am interested in both thing, but more to create layout.
Batch Printing example:
maratovich....it is a payment tool....I want create a tool with VBA and i would pay :unsure:....
Some bits you need to change are shown in red, copy and paste my 1st post to Notepad save as "Plot-Multi-Mspace.lsp". make changes to the code as shown below, post a dwg with say two title blocks a RAR is a nuisance for me then could change code for you.
To run type Appload and pick the lisp Load & close it should run.
; By Alan H 2013
(setvar "osmode" 0)
(setq ss2 (ssget "x" '((0 . "INSERT")(2 . [color=red]"Da1drsht[/color]")))) ;[color=red] title block name[/color]
(setq index 0)
(repeat n
   (setq inspt (assoc 10 el)) ;[color=mediumturquoise] insertion pt of title block[/color]
  (setq xmin (- (cadr inspt) [color=red]6.0[/color])) ; [color=red]offset pt lower left[/color]
  (setq ymin (- (caddr inspt)[color=red] 6.0[/color]))
  (setq xmax (+ xmin 813.0)) ; [color=red]hard coded for 813 wide 6mm offset[/color]
  (setq ymax (+ ymin 566.0)) ;[color=red]hard code for 566 high[/color]
[color=red]; scale 1=2 is for an A1 sheet plotted on A3 paper[/color]
[color=#ff0000]; dwg to pdf means we can check if it works rather than waste paper[/color]
 (COMMAND "-PLOT"  "Y"     "" [color=red]"DWG to PDF[/color][color=red]"[/color]
       "W"   xymin   xymax [color=red]"1=2"[/color]  "C"
       "y"   [color=red]"Designlaser.ctb[/color]"      "Y"   "" "n"   "n"
       "y" "N" "N" "Y"
