shennig Posted January 18, 2017 Share Posted January 18, 2017 Hi, I am using Revit 2016 & have set some keyboard shortcuts for commands. what i would really like to do is set a keyboard shortcut for "flip section" & "go to view". can any of the revit gurus shed some light on how to achieve this as the commands do not appear when i search in custom keyboard interface. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted January 18, 2017 Share Posted January 18, 2017 Since it's not available in the list I'm not sure that it's possible with an out-of-the-box solution. Is it too much trouble to select or right-click and choose the Flip control, as well as double-clicking the Callout Head to activate the View? I'm all about reducing keystrokes, but not sure this is a real time saver in the end. I wonder if Dynamo could be used to create something for you on this. You may want to check out the programming forums over at the Dynamo forum: http://dynamobim.com/ -TZ Quote Link to comment Share on other sites More sharing options...
halam Posted February 20, 2017 Share Posted February 20, 2017 Not possible and Dynamo won't help since this is about DATA manipulation and does nothing with user interface.. Put in a wish for more options on keyboard support. I will support it. Quote Link to comment Share on other sites More sharing options...
