Plot all layouts with one command
gmmdinesh
Hi Everyone.. I need help again..In my project have lots of different size layouts( A1,A2,A3 &A4 all layouts in one *.dwg file).I need a lisp for plot all layouts as per layout size with one command.
Can anyone help me.?
Thanks in advance.:)
Hi..lee mac..
Thanks for your reply..
I have tried PUBLISHE command..but it initiate few settings for proceeded the process at every time. and also it takes lot of time to publishe all layouts... i need automatically plot all layouts witout any initiate settings.
Thanks again..:)
You could start with something like this:
(foreach layout (layoutlist)
 (command "_.PLOT" ... )
Hi..Thank you so much for your reply..
FYI.
I have attached sample file. in this file have only four layouts.
But in actual file have minimum 20 layouts.
sample.dwg
Thanks again.:)
This seems to be the simpliest way:
(defun C:test ( / cmd )
 (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0)
 (foreach Layout (layoutlist)
   (command "_.-PLOT"
     "No"                                        ; Detailed plot configuration? [Yes/No] <No>: No
     Layout                                      ; Enter a layout name or [?] <Layout1>:
     ""                                          ; Enter a page setup name
     "DWG To PDF.pc3"                            ; Enter an output device name or [?] <DWG To PDF.pc3>:
     (strcat (getvar "DWGPREFIX") Layout ".pdf") ; Directory to save
     "No"                                        ; save changes to page setup?
     "Yes"                                       ; proceed with plot?
   ); command
 ); foreach
 (setvar 'cmdecho cmd)
); defun C:test
For the detailed plot configuration check scottbolton's post in this thread.
Grr as Gmmdinesh implies different size layout title blocks, the code would need a check for the title block name and then the correct sheet size could be used. I would also suggest use a Window rather than layout a bit more reliable.
Grr just a bit of an add to the plot pdf same method this is plot pdf by sheet range rather than all.
Gmmdinesh you need to add a title block of some form to each layout so the size can be determined. Even a rectang as a block, this way can work out the two corners of the plot area. See the code example below, this is a A1 sheet plotted to a A3 sheet.
plotA3Pdfrange.lsp
getvals.lsp
I don't understand this -> "but it initiate few settings for proceeded the process at every time"
You also say "i need automatically plot all layouts witout any initiate settings" - but that is *exactly* what the Publish command does.
It prints layouts with no interaction from the user needed.
Same for publishing from the Sheet Set Manager.
  • 5 years later...
   (command "_.-PLOT"
   ); command
 ); foreach
); defun C:test
It's good but it is using the Layout Name as Filename.
can it use the actual filename instead?
All sorts of output is possible based around dwg name, eg mydrawing-D01, mydrawing-D02 or layout names or or or, it really comes down to what you want in the way of a file name how can 88 layouts be just dwg name ? Well yes if using correct pdf writer or for me join individual pdfs into "dwgname-D01-D88"
