RobDraw Posted January 15, 2017 Posted January 15, 2017 2017.1.1 is the last update. If it is installed AutoCAD will report it as such, not SP1. Quote
abraCADabra Posted January 16, 2017 Author Posted January 16, 2017 I tried the repair, to no avail. I am going to try to uninstall/reinstall. I am thinking this is the only option I have left. I hope this works!! Quote
ReMark Posted January 16, 2017 Posted January 16, 2017 There is a recommended procedure to follow posted at the Autodesk website. Quote
RobDraw Posted January 16, 2017 Posted January 16, 2017 Did you check to see if AutoCAD is fully updated? I'm not saying it will solve your problems but it might. A reinstall won't fix it until all the updates are installed if the fix is in an update. Quote
abraCADabra Posted January 16, 2017 Author Posted January 16, 2017 I think my video card and ram are ok. You can check the specs in my profile, but I think they are ok. I have autosave set to every 5 minutes. I tried turning off the autosave, then I closed out of acad, rebooted and restarted acad again, and still doing the same. Quote
abraCADabra Posted January 16, 2017 Author Posted January 16, 2017 I will check and see if an update is needed before I do anything else. Quote
