Lisp Request - Select object in paperspace in across multiple layouts
eyeofnewt555
On 1/11/2017 at 8:53 AM, Grrr said:
This should grip all blocks in the drawing, with the same name:
(defun C:test ( / blk SS nSS i e )
 (setvar 'errno 0)
 (while (/= 52 (getvar 'errno))
   (setq blk (car (entsel "\nSelect block to filter <exit>: ")))
   (cond
     ((= 7 (getvar 'errno)) (princ) (setvar 'errno 0))
     ((and blk (/= "INSERT" (cdr (assoc 0 (entget blk))))) (princ))
     (blk
       (setq blk (vla-get-EffectiveName (vlax-ename->vla-object blk)))
       (setq SS (ssget "_X" (list (cons 0 "INSERT"))))
       (setq nSS (ssadd))
       (repeat (setq i (sslength SS))
         (setq e (ssname SS (setq i (1- i))))
         (and (eq blk (vla-get-EffectiveName (vlax-ename->vla-object e)))
           (ssadd e nSS)
       (sssetfirst nil nSS)
       (setvar 'errno 52)
I found this lsp and have been using it for a few years, great lsp. I used it today to delete a block from all layouts but when I switch from one layout to the next, the block still exists in all subsequent layouts. I want to delete our title block from all layouts, only 9 layouts, and purge it. It's the same identical block with the same name, any reason the above lsp wouldn't select them all?
Thanks
Thanks
Using this as a base try this code:
(defun c:foo (/ e n s)
  (if (and (setq e (car (entsel "\nPick block to delete: ")))
	   (setq n (assoc 2 (entget e)))
	   (setq s (ssget "_X" (list n)))
    (foreach o (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex s)))
      (vl-catch-all-apply 'vla-delete (list o))
Edited by ronjonp
